Blue Smoke after valve cover replacement
97 OBS F450. I just replaced the valve covers, upgrading to the newer Super Duty style, and swapped out the glow plugs. Got a little oil in the plug holes, but only on 2 or 3 holes. After I got it back together, it smokes blue. Nothing at idle, a lot at high rpm. Any ideas?I'll double check my wiring, but I swore I had it.
About a mile total on a completely heated engine. Seems to be missing some power as well. I may have botched my wiring when soldering the SD pigtails. Anyone have color codes for the OBS injector wiring? I followed the diagram on this post, but I don't see the {Tan/Yellow} wire; front driver side command wire.
https://www.powerstrokenation.com/fo...how-i-did.html
Actually, she smokes pretty bad at idle. Wiring is right, now. No power-loss, fluids are fine, and idle is mostly fine. Close one door, and another opens.
Last edited by Pyroneer; 01-20-2019 at 10:47 PM. Reason: Nothing is ever that easy.
Appreciate the replys. Here's what I got for ya. Also, I don't think the smoke is blue. It's more of a white/grey. Very hazy; Stays in the air for a long time.
-Absolutely no oil cap movement. The cap actually get sucked on at 2k rpm. Just the usual 'choo-choo' steam.
-No tester for the injectors. I did unplug each one with the truck running for a crude test. Only 2 injectors dramatically changed the idle.
-The old injector connects had 1 or 2 broken pins, I think they were glowplugs. They were coated in oil, hence the gasket swap. I may have resurrected a dead injector in the process.
-Ordered another fuel filter. It doesn't look horrible, but it's the one I used after a rust/water issue I had awhile back. It had a few sips of rust, but I drain the bottom of the fuel bowl fairly often. Until I know my tank is cleaner than a whistle.
-Ohm tested all injectors and GPs. We're golden, Ponyboy
I'm leaning toward an injector issue. I have no mileage info on them, but it had I think 4ish newer-looking Alliant Power injectors.(I forgot the amount) But I am still waiting on my fuel filter, though. How accurate is the unplug injector while idle test? Or did I kill an injector or 4 by doing it?
unplugging injectors can maybe fine on that is bad.
I have two that don't do much to idle on pass side unless both unplugged.
IDM only shuts down a bank on a short, not an open that I am aware of.
The fuel filter prevent water getting into the injectors but if the filter failed then you could have more issues with the rust and water in the injectors
You can also measure armature clearance. Pull the injector solenoids, you’ll see a small square plate. Use a feeler gauge to measure the clearance between the armature plate and injector Boddy. A new injector has .004 and anything under .002 is a worn injector.
Inderstanding how thiese injectors work will help you a lot.
HEUI - How High-Pressure Oil Injection Systems Work - Diesel Power Magazine
Pyroneer
10-20-2018 08:09 PM
Jeremy38
08-13-2014 04:07 AM
army_sapper68
02-07-2011 07:15 AM
