Looking at buying a 2012 stx
Fist of all, are you in a part of the country where they use salt on the roads? If so, crawl under the truck and check for rusted out rocker panels and check the bed cross members for rust. Second, make sure the engine does not have the coyote tap/tick. This will be pretty apparent if the exhaust is not too loud. Also need to look and listen for drive shaft clunk, any vibrations and overall condition of the steering and suspension.
It's not a cam phaser issue but a distorted block - check out this thread here. There are some good posts with video. My truck was subject to this and needed to have the block replaced (luckily under warranty)
https://www.ford-trucks.com/forums/1...-knocking.html
dustinleavitt2000
05-23-2003 12:55 PM
