77 F150 w/ 460 not revving above 3400 rpm's
Okay, first of all, the truck runs pretty well, considering it still has the Motorcraft 4350 spread bore carb. Fires up on the first try and gets me everywhere I want to go. Acceleration is steady, no hiccups or stutters. Idle is the only things that is not perfect, but I'm scare to touch it anymore since it gets me up the road and back.
However, I installed a tachometer this weekend and verified what I had thought for a while now: It's not revving as high as I'd expect. I drove it quite a bit yesterday for the first time still installing the tach and I couldn't get it past 3400 rpms and that was the only time it got that close. Most of the time 3000 was it. If I floor it from a slow roll, it accelerates smooth and steady, but it doesn't get very high before shifting. I believe the rear has a 3.53 or so (or whatever Ford provides in that ball park). I'm turning about 2000 rpm at 55 mph with 30 inch tires.
First thing I know to check is whether the throttle linkage is traveling the whole distance when depressing the gas peddle. With the entire setup (carb, intake, linkage) being stock, I don't know why it wouldn't. I was also told that there's a modulator that has a vacuum line going to it on the transmission that I can adjust to get deeper shift points.
Someone asked me if I had enough fuel pressure but it never feels like I'm running out of fuel. Back when I was adjusting the floats, I did have them set too low and would run out of fuel at higher speeds, but I got them adjusted properly, I feel.
I just ordered a Holley Avenger 770. This 460 has an RV cam but that's about it right now. Headers and aluminum intake down the road. We'll see if that makes a difference but if anyone has any idea what what limit rpms, while at the same time running pretty well, I'm all ears. Someone also asked me about timing, but the man that built this motor was a very good mechanic and I don't think the timing is an issue.
Thanks
Thanks
it wasn't clear from your post if you tried revving while parked or if you were only checking max Rpm while drving...
It would only take you 30 seconds to confirm if the primary butterfly is opening all the way by looking down the throat of the carb...
Have you checked with the "man that built this motor"?
As far as the man that built it, I can ask him at some point. He has been a great friend of the family for my entire life. He is now in his late 70's, so I don't like to burden him with a lot of this. My dad bought this truck from him around 2002 and my dad decided to pass it along to me last December. He has helped a lot with this truck over the years and you never want to become burdensome with things like this. It's why I don't like to sell friends and family cars myself.
Your rpm at 55mph seems a little low with 30” tires and 3.53 gears? Gear ratio sounds off also? My 77 F150 is a 4x4 and has 3.50 gears in it and at 60mph I want to say I’m turning 2200rpm and I have 33” tires on mine. I pulled my engine out of a 77 F350 2wd camper special. Engine has 104,000 miles on it.
Anyways my 460 is pretty stock. Factory cam, stock heads etc...Carter AFB carb is on the top of it. You gotta remember the stock motors are low rpm torque engines. Not hi rpm engines. The biggest thing holding it back is the camshaft.
Leaving mine in drive and stepping on the pedal hard (not necessarily beating it to the floor boards) the truck moves right out and when I do watch the tach it shifts at a peak rpm of about 3600. So where not far apart.
On the freeway my truck will do 75 and the engine doesn’t seem to be working hard. Just tools down the road. I haven’t driven it now since late October but I want to say at 70mph it’s like 2600/2700 rpm. Oh yea and it doesn’t matter if city driving or on the high way.....about 8mpg. LOL!
Running smooth at low rpm but won't tach up makes me think valve train problems. Have you pulled the valve covers to see if your rockers are loose? If its not running rough at 3400 rpm (valve float), and you have no vacuum leaks, or blow by, I'd be thinking the camshaft lobes are wiped out and it just won't flow enough air to rpm past 3400.
What I'm saying for sure is that it won't get past 3400 rpm's, at least in drive (D). I haven't tried it by manually putting it in 1st yet. I'll give it a try tomorrow afternoon when the road conditions are safe enough. I guess whether it's shifting too soon is subjective. I never really thought about it shifting too soon before putting the tach on. But any other vehicle, whether it's my work truck (2015 F150 with the standard V6 - no EcoBoost), my 2005 Nissan Altima 3.5 or my 2002 Escalade with the 6.0, when I mash the gas to the floor, they all rev to red line. I know the 460 is a low end torque monster that's not supposed to rev to 7000, but I've had many guys tell me it should get close to 5000. Hopefully I can see what this carb is doing and determine if the secondaries are opening or if it's just the kickdown on the transmission I'm feeling. When my dad gave me this truck, I was expecting a lot more "umph" from it. It's got about 40k on the rebuild, which including a mild RV cam. Other than that, she's completely stock.
It should rev until it floats the valves even if you had no secondaries it would just take longer to get there.
In order to determine if you have an engine problem or a transmission problem you need to hold it a lower gear and see what happens.
lots of 460's are low compression and if it is then it's going to be a dog , this might be your power problem. but it still should rev normally.
One thing that I did was address the poor idle that I was having, after it warmed up. Adjusted the air/fuel mixture, with the use of a vacuum gauge and got it from barely 14/15 to a nice, steady 18. Now, the more I get comfortable with this carburetor, I'm wondering if I should have purchased the Holley Avenger 770 that I just ordered. All the information I've found said that the Motorcraft 4350 is a 715 cfm carburetor. So 770 shouldn't be out of the question, right?
What kind of kick down linkage, etc.
I mean, does it have a rod that comes up from behind intake and runs down to transmission? If so, you want that rod to reach full travel at WOT. To check it, requires popping rod off ball at carb or unbolting it, push it down and open throttle and compare, adjust rod to make match. When adjusted correctly, governor in transmission will determine shift point in passing gear.
My '77 will kick down and pull to near 5k or when I relax throttle to let it up shift from either 1st or 2nd as the case may be … which I will usually do. I just don't like reving it way up there.
I put a shift kit in trans in late '80s which included some mod to trans governor wgts or springs, I think it shifted at a slightly lower rpm stock before that.
Mine is oem 3.50 gears, C-6, and just driving along, about 2,400 give or take at 60 mph, 31/10.50-15s.
770 cfm is OK, but that oem mtrcraft was / is enough.
You do know that 460 was swapped in.
It's not that I want to race the truck or that I will be constantly flooring, I just think that it's odd that it won't get up to 5000 like a lot of folks (including you) say it will. A guy on Facebook did share a video with me of a vacuum module on the front of the transmission that you can tweak and that will prolong the shifts. I may tinker with that at some point to see if will be allow the rpm's to clime higher.
I believe this 460 is the one that came with the truck.....is there a reason to believe it didn't? I can ask the man that my dad got it from if that is the case.
There is likely a link on the carb to stall / prevent the rear air valve over secondaries from opening while choke is cold or closed.
I thought you had a 4wd, my bad.
I have had guys swear they had a 460 and argue when the parts they bought din't fit …. go look and sure enough, they had a 351M or 400.
Valve Cover Bolt Numbers
2 bolts: "Y" Blocks
239/256/272/292/312 (produced from 1954 to 1964)
5 bolts: FE Series
332/352/360/361/390/391/406/410/427/428
6 bolts: SBF group
221/260/289/302/351W
7 bolts: 385 Series
429/460
8 bolts: 335 Series
351C/351M/400
That vacuum modulator will cause part throttle shifts to be delayed a little when engine is under load, but is not intended nor functions as a kick down or passing gear. I'll include pictures of extension.
2 bolts: "Y" Blocks
5 bolts: FE Series
6 bolts: SBF group
7 bolts: 385 Series
429/460
8 bolts: 335 Series
351C/351M/400
Also, there was no 4 barrel carb motor offered in that truck, just 2 barrel 351m or 400 and usually the kickdown rod isn't long enough to work the trans all the way to "kick down" or passing gear. The oem 2 barrel intake places the carbs two barrels center of engine and most 4 barrel intakes move the carb two primaries forward to center the whole carb over engine, so kick down rod is often too short. Even though adjustable, I had to make an extension when I put a 4 bbl carb & intake on because of this.
2 bolts: "Y" Blocks
5 bolts: FE Series
6 bolts: SBF group
7 bolts: 385 Series
429/460
8 bolts: 335 Series
351C/351M/400
2 bolts: "Y" Blocks
5 bolts: FE Series
6 bolts: SBF group
7 bolts: 385 Series
429/460
8 bolts: 335 Series
351C/351M/400
"Ford trucks, Lincoln cars, Jeep and AMC continued to use Autolite four-barrels with a third generation carburetor referred to as the model 4350. Lincolns and trucks with the 460-cu.in. engine continued to use the 4350 until 1978. American Motors eight-cylinder engines also made use of the Autolite four-barrel carburetors in 1975 and 1976, and Jeep continued the use of the 4350 until 1978."
- 1975-'78 Lincoln with 460-cu.in. engines
- 1973-'78 pickups with 460-cu.in. engines
- 1975-'78 AMC and Jeep with 360, 390 and 401-cu.in. engines
I checked the kick down this afternoon. I disconnected it from the carburetor and moved it fully, then reconnected it and moved the throttle fully. It goes the distance like it should.
I've got it purring like a cat right now. Beginning to wonder if I will send the Holley 770 back. I've got a leaky radiator and an exhaust leak that needs to be fixed.
