new respect for those who did exhaust studs; there kicking My A$$ - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Reload this Page >
Old 01-13-2019, 12:17 PM
90limited
90limited is offline
90limited is starting off with a positive reputation.
Sooooo.... Been working on the X for three days trying to replace exhaust manifold studs..
Day one: put on jack stands removed tires, inner fend liners, shocks and shock mounts and soak all the studs in PB. Also learned that front shocks were toast.
Day two: remove two studs on passenger side and three on driver side. That leaves two bolts/studs on each side. the others where already broken off. The second and third bottom from the front are still on each side. The ones that have almost no access because of the frame support for the motor. The nuts are rusted and there is no way to pound on a slightly smaller socket.
Day three: take the dremel with the wand attachment and am able to get the the third bottom nut on driver side off. Also was able to get the third bottom nut on passenger side about 2/3 cut using dremel right angle head before the gears in the head striped. Went to buy another and out of stock.... damn. I was able to pop the 2/3 cut nut off with an air chisel. That leaves me the second from front bottom on each side. The heads are rusted and I cannot get a socket to grab. For the life of me can't figure out how to get the dremel wand or anything else in there.
The crusty white pig is kicking my A$$. This is supposed to be the easy part. Haven't even started trying to remove the studs yet...... Anybody have any words of wisdom?
They're kicking my A$$. Can't edit the title......
Old 01-13-2019, 04:14 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is online now
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
If I recall correctly, I was able to force either a socket or a small box wrench onto every stud nut, I started with only two missing though. Maybe try fitting a socket over the nut and then lever it into place with a pry bar and then work the ratchet into the socket......? Those lower ones are a challenge.
Do you have a MIG welder on hand to weld some nuts to the broken studs to spin them out? It really helps.
Old 01-13-2019, 04:34 PM
90limited
yup have a mig... also have left handed drill bits. Hope I don't need them however. If I have to drill I might get one of the drill template thingy I've seen on amazon.
Haven't been out to the shop today. Feeling sorry for myself last night that I can't even get the manifolds off; so I have a long conversation with brother bourbon. Head little thick this morning. I'm planning on going out after dinner.......
Old 01-13-2019, 07:29 PM
Wishbone
Wishbone is offline
Wishbone is starting off with a positive reputation.
Did mine a couple weeks ago. I cut all mine off with a torch and have the scars to prove it. Had 8 broken below flush but they weren’t my worst ones. Welded build up then washer then nut, break off repeat�� Ended up drilling two,both on drivers side cly 2 bottom which was the hardest and Cly 4 top. Remflex gaskets highly recommended but they need to be torqued multiple times,they are nice and thick. Luckily I have a hoist, and I still would say it was PIA.
Old 01-14-2019, 08:59 AM
90limited
I have the remflex gaskets. Good to know on the re torque. I'll leave the fender liners off for the first couple of drives until I think everything has settled in, assuming I get the damn thing put back together.....
Old 01-14-2019, 09:43 AM
Flyboy1100
Flyboy1100 is offline
Flyboy1100 has a great reputation on FTE.Flyboy1100 has a great reputation on FTE.Flyboy1100 has a great reputation on FTE.Flyboy1100 has a great reputation on FTE.Flyboy1100 has a great reputation on FTE.
you took the shock tower off too? that really helps with clearance.
it is a PITA for sure, i would assume/plan on drilling some if you are having this much trouble just removing/breaking the old ones off.
you can probably just unbolt the mount and lift the engine a bit to get more clearance too.
Old 01-14-2019, 09:45 AM
Flyboy1100
i think i went around/criss cross/etc like 4-5x per manifold trying to get the remflex torqued. 3500 miles so far and so far so good. maybe i overtorqued them, but i hope not! they definitely have a lot of squish
Old 01-14-2019, 11:39 AM
90limited
Raising the engine now. Have fan shroud lose and trans cross number bolts off. Ok the use oil pan to lift motor? Always did that with my small blocks
Old 01-14-2019, 02:34 PM
90limited
Ok. Motor raised. Got passenger manifold off. About halfway cut through last bolt on driver but gotta stop and cleanup for work. 😡
Old 01-14-2019, 03:00 PM
Flyboy1100
well, progress!
at least with the motor up installing and torquing the lower bolts will be a bit easier.
Old 01-15-2019, 01:07 PM
90limited
Ok.... both manifolds off. Only one broken stud passenger side. Nut welded on and cooling. 4 studs out driver. Two already broken (one was broke before I started). 4 studs to go. Fingers 🤞🏻
Old 01-15-2019, 01:54 PM
wizkid00104's Avatar
wizkid00104
wizkid00104 is offline
wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.wizkid00104 has a great reputation on FTE.
Good luck. I will be doing this at some point. Small tick now, and I am not looking forward to it.
Old 01-15-2019, 02:09 PM
90limited
Broke one stud each side. Top front. Found the best way is to soak over night. Then Heat with propane torch. Squirt PB while still hot. Let cool. Put on stud extractor and tighten to the point you think the stud might break. Leave extractor on stud and heat aluminum head with propane torch. Hit with PB again and she comes out. Didn't break a single one this way.
Welded the passenger stud twice now. Keeps breaking nut off. I have some dry ice in freezer. Might try super cooling it.
Old 01-15-2019, 02:19 PM
wizkid00104
Have you seen the drill guide for removing the studs? There are several tools like this of varying prices.
https://www.ebay.com/itm/Lisle-Ford-...u5Jy:rk:9:pf:0
Old 01-15-2019, 02:32 PM
90limited
Yup seen the drill guides. Was keeping that as last resort so to speak. The two studs that broke had good solid shanks just corroded to the head. They will likely have to be drilled. I have left handed drill so maybe I'll get lucky.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
