Are there any 4spd manual transmission upgrades...?
I have an 1986 E150, straight 6 with 4spd on the floor, manual shift. If cash isn't an issue, are there any transmission upgrades out there....? Something with more gears, or an aftermarket build, or something like that?
I don't want a Gears Vendors extra box, or anything like that, but since this is a ride I take on the highway A LOT and will have the vehicle a really long time, if there were any kind of awesome upgrade to the transmission where I'd have more gears and a bigger range and all of that, it would be very interesting to explore the options. My main interest is smooth driving, best mileage, and I don't mind the extra shifting. I never really pull anything.
I assume if anyone would know, it would be the folks in here.
I don't know the axle ratio, but it was ordered by the original owner for highway use. It actually works just fine, but sometimes I do feel like it would be cool for a few gears in between the ones that exist. I realize anything will probably cost the price of the van, but this is more about my use of it, since it's one of those things I really enjoy. Not so much about how much I have into it.
A T5 might have an OD and R gear too tall to work with your axle. That said, you need to find out what your axle is and what is your tire size? No sense in putting in a trans that ends up useless in first or OD or R.
The AX15 might be another option, but again mostly found in 4WD Jeeps.
For what you are talking about I'd probably go with the Mazda M5OD.
To me it sounds like you'd probably be happiest with a car type of transmission over a truck style. The Mazda 5spd & ZF 5spd are bigger( size wise ) truck transmissions.
What kind of budget are you working with on this? If cash really isn't a issue I would look into either a Tremec 5spd or a T56 6spd. Either would be a great transmission but would be pretty expensive. They would be the best options if you don't plan to do much heavy towing and manly use the van as a driver. They will have good gearing and pretty much bullet proof behind a 300. But you'd probably also want much steeper gears in the rear axle to take advantage of the OD gear/s.
A much cheaper option would a T5 out of a V6 SN95 Mustang. It's not the strongest transmission but stronger then what you have now. It should do fine as long as you don't plan on many high rpm clutch dumps or power shifting. I believe it would place the shifter close to your stock one just a little more towards the center of the van. Pretty nice shifting and would give you 4 gears + a OD gear. I've seen these go for as little as $50 at some u-pull it yards when they have specials. But otherwise I've seen them sell for $200-$400. You would need a taller shifter handle then what they come with.
Are you sure the T5 is the same bolt pattern? I thought it was different. But I'm probably wrong.
Ok That's what I thought but it's been almost 20 years since I owned any of my Fox chassis Stangs. So I couldn't remember for sure.
But I do believe the SN95 V6 T5's had a 164T bellhousing. Which should work out for the 300. Just make sure to get the bell housing, block plate clutch fork, etc.with the T5 The down side is it should be a cable set up. So a bracket will need to be fabbed up to mount a slave cylinder on the transmission side of the fork instead of the engine side ( like the stock van should be ) . And a slight modification will need to be made on the end of the fork for the slave push rod.
That would be the cheaper way to do things. The easier would be to buy or have an adapter plate made to mount the T5 to the stock van bell housing. But I have no clue what those would cost.
I was thinking of a T5 conversion when I found FTE in 2004. It never happened, but I did contact these folks and the answer is an adaptor plate. It takes care of the pattern and depth issues. I mentioned the adaptor in post 2.
Adapter plate, T-5, Wide pattern Ford, 289/302/351 & 1967+ 200ci, 1983-93 Ford T-5
