302/351 winndsor engine oil leaks...??
Received 4,132 Likes
on
SBF's have been notorious for leaking at the china rail ends which were originally sealed with a cork gasket and a spot of silicon sealant at the intake ends. Felpro realized the problem with the cork deteriorating over time and revised the gasket with a rubber gasket to fit the rails. That with a little permetex has always worked for me. I think there are many that have just used a 1/4" bead of RTV on the rails to substitute the rail gaskets. I also replace the dist housing gasket during this procedure. Time consuming repair but easily done.
At the shop I ran we did the oil dye test with the black light but was more a pain to make sure all areas were cleaned before installing the dye.
mike L
03-27-2008 12:48 AM
fatherdoug
05-30-2003 10:20 AM
