Truck won’t shut off
So update in case any cares.
We had some snow recently and I almost forgot to have him check but...wet carpet on drivers side.
So.. GEM pulled and dried, Fuse box dried. Same issue. Connect batteries and everything is in the RUN state.
So replaced switch on steering column.. Truck starts and stops as it should now, but...still in RUN state even with key off. Weird but PROGRESS!
Pull GEM again and dry some more. Reinstall and same thing. Only now.... When try to start with key... just a single CLICK. Sooooooo
Check all connections, clean anything found with any corrosion. Still no go,
By pass the solenoid on the firewall and it starts. WTH!!! So will replace solenoid today.
I may have to steal my buddies truck. I think he is contemplating using some percussion engineering with a 12lb sledge hammer.
OK New solenoid...still no start. Only a CLICK. But can bypass the solenoid and it starts & runs just fine. Going to check the switch on the steering column again to be sure it isn't loose or that the rod isn't pushing it far enough to turn over the starter. Batteries checked and both are good to go.
A good troubleshoot is to test start/stop function from the ignition switch only. You'll have to pull it down and move the switch by hand, this is very easy. In fact, this switch is why our truck are so damn easy to steal. If all functions work in the right order on the switch, then you likely have an actuator rod or gear problem and it's time to start digging.
My ignition actuator rod pin fell out once, it is far from easy to get to but it can be done. It's buried in the column between the switch and tumbler assembly. Pain in the *****. I posted sort of a how-to thread about this a while back, last July maybe? It can be done without pulling the whole column out but you need patience and steady hands.
On edit:
jonnygorgo
29
03-12-2014 06:36 PM
bc4x4f250
04-29-2013 05:18 PM
power bus
16
01-12-2008 11:00 AM
