Custom 2.5" level kit huge improvement in handling and ride
Black Rhino Warlords 22x10 +12, 6.0 backspace with 37x12.50R22 Toyo RTs
https://www.blackrhinowheels.com/off...hp#wheel-specs
https://goo.gl/images/BdnD5L
Mine has been great with the ReadyLift 2.5" level kit and stock shims, but I didn't have the opportunity to drive it prior to the lift and I have dual-stabilizers so could be masking any issues. I also had to go back and add the relocation bracket and bump stop ext. so not surprised if they took other shortcuts.
I think the adjustable track bar helps considerably as it centers the axle and keeps the steering parallel like it oem geometry. The alignment shop said some trucks need caster shims and some don't when going with leveling kits or under 3" lifts. Lifts 3" or more should definitely should have Radius Arms or RA brackets for correct caster from what i'm hearing.
Sometimes my post don’t match what I’m thinking lol as I’m no computer whiz
I failed to see / read the $400 alignment comment that supposedly didn’t need caster corrected.
#29
How much lift are the snow plow springs netting over stock?
I’m trying to plan my setup out with the heavy service spring (mid level, below yours) before the truck arrives as it was ordered. I’m probably gonna have 50% of that lift.
Also is the trackbar heim linked on one end? What’s the service life on the other side bushing?
#30
I ordered H/D svc frt suspension on both my F350 & I doubt their 1” higher than stock.
The 17-19 Super Duty Tracking Bar has a ball joint / tie rod type tapered stud in the lower end that bolts to the axle.
I’d guess both ends should last 75-100k Miles of NORMAL Hwy driving & that’s a Guess.
tdsutton
2017+ Super Duty
09-17-2019 11:46 AM
