No parking brake - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
No parking brake
Old 01-11-2019, 03:02 PM
264WSM
264WSM is offline
264WSM is starting off with a positive reputation.
No parking brake
I have a new to me 2000 F-350 dually. The previous owner stated that he drove 50 miles with the parking brake engaged and it hasn't held since. The rear pads look good.
Where do I start???
Old 01-11-2019, 04:21 PM
Colorado350's Avatar
Colorado350
Colorado350 is online now
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
There’s dozens of videos on YouTube. Probably need to be rebuilt and if the light doesn’t illuminate replace the switch in the pedal.
Old 01-11-2019, 09:24 PM
CousinCarl's Avatar
CousinCarl
CousinCarl is offline
CousinCarl is gaining momentum as a positive member of FTE.
I'd clean the switch with silicone spray before replacing it. Usually it's just dirty.
But it sounds like the shoes just need adjusting.... https://youtu.be/iZ5f6YeCgZo
You can do it with the wheel on there still btw.
Old 01-12-2019, 01:50 AM
burnthelight88's Avatar
burnthelight88
burnthelight88 is offline
burnthelight88 is starting off with a positive reputation.
The rear PADS look good, or the rear SHOES look good? The PADS don't have anything to do with e-brake. The SHOES hold the e-brake. Did you just use the words interchangeably even though they aren't, or did you check the wrong part?
Old 01-12-2019, 08:58 AM
Chuck's First Ford
Chuck's First Ford is online now
Chuck's First Ford has a very good reputation on FTE.Chuck's First Ford has a very good reputation on FTE.Chuck's First Ford has a very good reputation on FTE.Chuck's First Ford has a very good reputation on FTE.
glazed .... greatly reduces braking ability.
as does overheated brake shoe/pad material
50 miles.. if not glazed.. they were overheated.. replace..
its a simple system...
that or they are badly out of adjustment.. but I hoped you already checked that.
Old 01-12-2019, 10:03 AM
264WSM
264WSM is offline
No I didn't check adjustment
No, I didn't use the words interchably
My brother mentioned shoes , I pulled the wheels and only saw pads. I'll look at the youtube stuff, but I didn't see shoes or an adjustment.
As you can tell this is too modern of a vehicle for me!!
Old 01-12-2019, 10:21 AM
264WSM
264WSM is offline
A video is worth 10,000 words. Now I know what to look for - Thanx
Old 01-13-2019, 12:03 AM
Dsimes
Dsimes is offline
Dsimes is starting off with a positive reputation.
Parking brake wires
Not sure if this is the place to post this but since the original question was about the parking brake I thought I would try. I'm installing an after market stereo and have to hook a wire to the parking brake wire. I found the wire the only problem is there are two wires instead of one. They are black and brown. Which should I hook to? Would the black be the ground and the brown the power? Why would their need to be a power and ground?
Old 01-13-2019, 01:46 PM
Colorado350
Why would a radio have to be hooked up to the parking brake? The switch on the PB, illuminates the light on the dash.
Old 01-13-2019, 02:45 PM
Dsimes
Dsimes is offline
modern after market radios need it for some of the features to work such as hooking up a new smart phone for apple play or android auto. They need a signage telling that the parking Brake was applied for the function to work.
Old 01-14-2019, 04:39 PM
burnthelight88
1- check instructions and make sure that hookup is actually needed, some have it as an option but if you dont hook it up things work just fine
2- if it has to be hooked up, most will just ground it out to metal and then they can use the features all the time
3- if you really want to hook it up, Id like to add that the parking brake switch in fords is notorious for corroding and not sensing it. For instance, with my parking brake on my light almost never illuminates. Sure you can clean up the contacts like I did on my last mountaineer, but again Id look for another route than actually using the parking brake wire
4- I have no idea which wire youd want to use at the switch, but a simple test light can solve your issue.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
