Future Fluid (motor, tranny and coolant) Change Modules
Suggestion for future improvements of changing out the motor oil, tranny fluid, fuel filters and coolant by using replacement fluid modules that come with fresh clean, proper fluids and built-in filters.
The modules would be quick removal and replacement heavy plastic that bolt in or snap in. The modules have their own filters or in the case of the fuel filter, the module is the filter.
It's so ancient to have to drain fluids and replace filters. Quick replacement modules would be much better.
