07 F-150 one issue after another now I'm stumped - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Reload this Page >
Old 01-10-2019, 05:02 PM
dyson77
dyson77 is offline
dyson77 is starting off with a positive reputation.
So I have been having issues with my truck lately 07 F-150 4.6 V8 STX
it started with a miss on #7 so I started to change the plugs and saw the entire right side was covered in oil.
So I took it to my shop to replace the blown gaskets ( honestly it was in the middle of a snow storm and I didn't want to do it in the snow )
Ended up replacing all but 3 coils and all the plugs . then I went ahead and replaced all the fuel injectors
I had a slight stutter so I ran Seafoam and lost the stutter.
Then it was showing P2196 and p2198 But I cleared them out on the recommendation it may be left over from before everything was changed,
it popped a code saying EGR bank 2 so I went and changed the EGR because it was rusted pretty badly and I was hearing a high pitch whine when I was accelerating
and the EGR tube connecting to the manifold cleared all codes and drove it for two days about 100 miles
last night it popped a new code P0430
I ran torque pro live results and it failed two areas
MID $22 TID:$80
Catalyst Monitor bank 2
Min 0Ratio Max: 0.609ratio
Current 0.754ratio
AND
MID $32 TID$82
Egr monitor Bank 2
Min -32.768kPa Max : -32.659kPa
Current : -0.845kPa
So I am completely stumped . the only thing on the EGR I didn't replace is the dual rubber lines off the top. What else could it be?
Old 01-10-2019, 09:20 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
the 2196 and 2198 codes are for #1 bank and #2 bank O2 sensors... The code says you have excess fuel at the O2 sensor.. Normally a misfire, or leaking injectors, bad spark plugs etc.. You have no misfire, so lets assume its not the plugs. ( what brand of plugs did you install ?) Since you just replace all the injectors, I would make sure they installed the 4.6 size and not the 5.4 motor size. injectors........... the P0430 means the excess fuel is starting to effect you catalytic converter on the drivers side.
----------------or are you saying all the codes are gone except the 0430 ?? That is cat converter problems starting on the drivers side.... due to previous fuel problems.
Old 01-11-2019, 11:50 AM
dyson77
dyson77 is offline
I apologize I worded it wrong in the original post the first two codes popped before I replaced the fuel injectors.
they are gone now. I installed auto light platinum plugs and Lifetime bwd coils.
yes the only code I am currently showing is the p0430
and when I run real-time information in Torque pro I get these two errors as well I can post a screen capture if you like
MID $22 TID:$80
Current 0.754ratio
AND
MID $32 TID$82
Egr monitor Bank 2
Current : -0.845kPa
Old 01-11-2019, 02:24 PM
steve(ill)'s Avatar
steve(ill)
Top Causes of P0430 in the Ford F150
There are many things that can cause the P0430 trouble code in your F150. Here are the most common ones.
  • Oxygen Sensor– The P0430 codes is thrown when the oxygen sensors on both sides of the exhaust have very similar readings. When the oxygen sensor is bad, it can cause a false reading and trigger the code.If the engine does not exhibit any of the decreased performance associated with a bad catalytic converter, it very well may be the oxygen sensor (or you haven’t noticed the performance loss yet).
  • Catalytic Converter– A catalytic converter is responsible for scrubbing out as much pollution as possible from the F150’s exhaust. Over time, they can become clogged. Although, modern catalytic converters are supposed to last the life of most vehicles, os there could be some underlying problem if it has clogged.
  • O2 Sensor Wiring– Over time, the oxygen sensor wiring can go bad. It is especially volatile since it is right next to the hot exhaust at all times. The downstream oxygen sensor wiring is especially volatile since it is so far from the ECM (more distance to travel.
Old 01-11-2019, 03:58 PM
dyson77
dyson77 is offline
So at this point would you recommend replacing both 02 sensors before I delve into the cats?
Old 01-11-2019, 05:15 PM
steve(ill)'s Avatar
steve(ill)
Im no expert, but if it was the O2 sensor I would think there would be additional codes ? ........... but its any ones guess at this point........... I bet the Torque Pro data is trying to lead you to something, but I cant say what.
Old 01-11-2019, 09:16 PM
dyson77
dyson77 is offline
very true but of the reason codes listed above the only ones left are the O2 sensor and O2 sensor wiring and the catalytic converter and since you are two sensors considerably cheaper I would think that might be the best bet
Old 01-11-2019, 10:26 PM
pdqford
pdqford is offline
pdqford has a very good reputation on FTE.pdqford has a very good reputation on FTE.pdqford has a very good reputation on FTE.
MID $22 TID $80 is testing the rear to front ratio of the bank 2 CAT monitor tests and it failed.
How long has cyl #7 been misfiring?
MID $32 TID $82 is testing the upstream DPFE hose and it failed the test.
Old 01-12-2019, 10:16 AM
dyson77
dyson77 is offline
you may have to dumb it down a little bit for me here. does that mean I need to replace the rubber hoses on the egr?
and the bank to does that mean I should replace the cat or the o2
Old 01-12-2019, 02:14 PM
steve(ill)'s Avatar
steve(ill)
not that simple.. it says the O2 sensors front and back ran a ratio test and it FAILED... Could be one of the O2 sensors was BAD, or could be they are reading correct and the CAT is not doing its job.
Old 01-12-2019, 04:59 PM
dyson77
dyson77 is offline
well the question of the day is is there a way to test if your catalytic converter is working properly the only thing I've read is you can walk up to it and smack it and if you hear rattling it's bad. my only concern is if I take it to Joe Blow muffler shop would they be honest and tell me that it was actually bad or is there a way for me to check myself
Old 01-12-2019, 09:53 PM
pdqford
pdqford is offline
Originally Posted by dyson77 View Post
you may have to dumb it down a little bit for me here. does that mean I need to replace the rubber hoses on the egr?2
I don’t know about a rubber hose on the egr.
But I would check the upstream hose on the DPFE.
Is it loose? Leaking? Completely plugged with carbon?
How many miles on vehicle?
Old 01-12-2019, 09:59 PM
pdqford
pdqford is offline
Typically you will get a code if an O2 sensor fails when the PCM runs an O2 test.
Try graphing both the upstream and downstream O2 sensors and see if they are different.
If they track one another the CAT isnít doing much.
Old 01-13-2019, 09:06 AM
dyson77
dyson77 is offline
I donít know about a rubber hose on the egr.
it has 130,000 miles on it I just replaced the full EGR assembly and there was two plastic ports that connected t two rubber boots along with a stainless line that ran to the manifold that I replaced,
forgive me but I don't know what a DPFE is I am still learning the terminology
Old 01-13-2019, 09:08 AM
dyson77
dyson77 is offline
I was reading some about removing the downstream o2 and then customizing the cat has anyone done this before? would it effect the performance of the truck. the upstream would still be there and that's the one that it bases the lean rich ratio correct?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
