AOD trans in a 1970 F100. - Ford Truck Enthusiasts Forums
Old 01-10-2019, 02:53 PM
427F100
427F100 is offline
427F100 is starting off with a positive reputation.
Has any one put an AOD trans in a 1970 F100? I am considering doing so. Any help would be appreciated.
Old 01-11-2019, 03:57 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
Shiftoholic
Freightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud of
Should be doable. Just need to get a cable to actuate it properly. Plenty of Youtube videos showing how to set it up correctly.
Old 01-11-2019, 04:10 PM
85e150six4mtod
85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
At the least, select an '88 to '93 unit from a truck or a V8. Early boxes are trouble. Ford fiddled with the transmission over it's life and '88 to '93 are the best. You can have them beefed with AODE and 4R70W parts, or if you like, move up to a 4R70W and get an aftermarket controller.
As indicated, the Throttle Valve (TV) cable/linkage is critical. It's not like a C4/C6 kickdown, and as said lots of adjustment info is available on line.
Old 01-11-2019, 07:03 PM
Red69
Red69 is offline
Red69 is starting off with a positive reputation.
You need a speedometer cable that goes from old Ford speedo to AOD. Lokar has them. I used a new flex plate and dust shield because the starter hole is in slightly different location. I also bought a PTI 10" converter and a TCI control valve that has constant pressure because of the horror stories about improper ATV cable adjustments causing transmission failures. There is a B&M shift lever you need to be able to use an after market shifter and a carb throttle spring return and a throttle kit from Lokar that has the bracket for the ATV cable and the right symmetry for the AOD.
I am still painting so I haven.t put the engine an trans back in yet, but it is all bolted together on the garage floor.
Old 01-11-2019, 08:07 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is online now
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
It's a very straight forward swap.
You didn't mention what trans you currently have, but if you have a C4, it's ALMOST a bolt-in.
Here's how I did it
https://www.ford-trucks.com/forums/1...-aod-swap.html
Old 01-11-2019, 09:07 PM
85e150six4mtod
Here's how I did it
What was the exciting conclusion there? Your last post on that one has me on the edge of my seat....
Old 01-11-2019, 09:20 PM
427F100
427F100 is offline
Thanks Freightrain,
It has a 3 speed manual now. The hump looks pretty low so I just bought a high hump in case.
Will go with Performance Automatic Street Smart Kit for FE. Expensive but looks like it should bolt up to my 427 FE.
Old 01-11-2019, 09:22 PM
427F100
427F100 is offline
thanks for the info
Old 01-11-2019, 09:23 PM
351Cleveland C4
I put a B&M shift kit in it myself a couple years ago. Helped it behave better and shift more consistently
Have somewhere around 80,000 miles on the trans by now. Lots of highway miles, Lots of towing, lots of stoplight drag races... it hasn't missed a beat yet.
I finally changed the fluid in it a few months ago around the 70k mile mark
Old 01-11-2019, 09:25 PM
427F100
427F100 is offline
Thanks for the reply.
Old 01-12-2019, 01:23 AM
85e150six4mtod
An AOD won't bolt up to an FE without an adaptor. $800+. And for a 427 you need a custom performance transmission.
Old 01-12-2019, 09:52 AM
351Cleveland C4
I missed the 427 part...
So my question now is, why????
AOD works good enough for a driver, but it's FAR from a performance tranny.
If you're gonna spend $1000 on an adapter, why not get something better???
Old 01-12-2019, 06:34 PM
85e150six4mtod
Ready to go for the FE, just $4830:
That'll work, and much better than a $100 jy transmission...
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
