'52 Ford F7 Big Job rear brake cylinders - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Large Truck
Reload this Page >
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 01-10-2019, 07:58 AM
AKVToni
AKVToni is offline
AKVToni is starting off with a positive reputation.
Hi,
I'm working on a '52 Ford F7 Big Job (old fire truck) and I'm looking for the correct partnumbers of the rear wheel brake cylinders.
I found them in the 48-56 Ford Truck Parts Catalog Illustration Section 21, page 8, Illustration P-690 nr 2261.
As it are lockheeds, I presume they also will be used on other vehicles
Old 01-11-2019, 12:53 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by AKVToni View Post
I'm working on a '52 Ford F7 Big Job (old fire truck) and I'm looking for the correct part number of the rear wheel brake cylinders.
4) 2Q-2261-A .. Rear Wheel Cylinder - 1 5/8" diameter / Obsolete
1948/52 F7 except tandem axle / 1953/55 F700/750 & C750 Cab Forward except tandem axle.
PARTS HOUSE CLEARANCE in Oroville WA has 1 = 250-878-3498.
Check with Chuck's Trucks, reference in 1948/56 forum.
Old 01-11-2019, 01:25 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
One thing to keep in mind if nothing pans out, original wheel cylinders can be reamed out and stainless sleeves installed. Most bores that old probably won't clean up well enough to simply install a rebuild kit because pitting is too deep.
Old 01-11-2019, 05:50 PM
AKVToni
AKVToni is offline
NumberDummy Did I overlook something and can I find these partnumbers myself in the caralog?
Old 01-11-2019, 09:31 PM
NumberDummy
NumberDummy Did I overlook something and can I find these part numbers myself in the caralog?
1948/56 truck catalog contains one bound paper text catalog, one bound paper Illustration catalog. You need both, because the illustration catalog only shows basic part numbers.
I found them in the text, but you have to know what the symbols for the various models 'decode' to.
Notice that 2Q-2261-A is listed for 1951/55 THQ, Q, QW, Z, ZW .. Not all these models were used in 1948/55, so first you have to find out what the symbols refer to, then what years they were used.
Symbols decoded on page XII in General Information Section at the front of the text. Symbols decode only lists 1951/52, but if it fits these years, it also fits 1948/50. All 1953/56 symbols are decoded.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
