Windshield wipers going on for no reason - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 01-09-2019, 06:12 PM
PGS67
PGS67 is offline
PGS67 is starting off with a positive reputation.
I have a 2016 F-F350 6.7 and have been driving around and the windshield wipers turn on when the switch is off. Wasn’t sure if anyone was having the same issue? I thought maybe the wipers go on like a courtesy wipe when you sue the blinker. Not sure what the deal is.
Old 01-09-2019, 07:02 PM
jav_eee
jav_eee is offline
jav_eee is gaining momentum as a positive member of FTE.jav_eee is gaining momentum as a positive member of FTE.
All the time or is it one swipe randomly?
Mine does that once in a while, especially when I've plugged something into the OBD2 port. Lately it's been doing that when I've been hunting. I'll park and turn the truck off and before I restart a few hours later I'll turn the headlights off (from auto). I do this because I've noticed the lights don't come on right away if I leave them in auto. I guess the truck freaks out because the door is never opened. When I start it I'll get one wipe and then everything is normal.
Old 01-09-2019, 07:07 PM
seville009
seville009 is offline
seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.
Probably the mfs itself (the multifunction switch). Had to replace it in my 2011 a few years back due due random wiper issues. Easy to do.
related thread
https://www.ford-trucks.com/forums/1...placement.html
Old 01-10-2019, 07:11 AM
Deuce40s
Deuce40s is online now
Deuce40s has a very good reputation on FTE.Deuce40s has a very good reputation on FTE.Deuce40s has a very good reputation on FTE.
It's pretty normal. Mine has done a single swipe 4 or 5 times right at startup. Like said above, replace the switch if you want.
Old 01-10-2019, 12:54 PM
12F350
12F350 is offline
12F350 is starting off with a positive reputation.
Mine was doing the same. The replacement part is the whole blinker arm/assembly . I recall the part being pretty cheap, around $38 from the dealer.
I changed it in my driveway in about 30 minutes.
Old 01-11-2019, 10:35 PM
Bohen
Bohen is offline
Bohen has a good reputation on FTE.Bohen has a good reputation on FTE.Bohen has a good reputation on FTE.
If you go into the settings and enter the vehicle menu there is a section labeled wipers in there it gives you the option to do when you turn your vehicle on the wipers to automatically turn on . That might help ?¿
Old 01-12-2019, 07:46 AM
SkiSmuggs
SkiSmuggs is offline
SkiSmuggs has a good reputation on FTE.SkiSmuggs has a good reputation on FTE.
I had my 1999 Ranger do the same. They replaced the switch.
Old 01-14-2019, 08:15 PM
PGS67
PGS67 is offline
I change the wiper switch and it fixed the problem. Thanks!
Old 01-15-2019, 10:56 PM
kper05's Avatar
kper05
kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Thank you for following up.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
