Cold Weather Idle Whine 6.7L - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 01-08-2019, 07:57 PM
joshjohnson93's Avatar
joshjohnson93
joshjohnson93 is offline
joshjohnson93 is starting off with a positive reputation.
Hi all,
Looking to see if anyone else with a 2017+ 6.7L PSD has had a cold weather whine/squeal at idle or high idle (750+ Rpm)? I have attached a video below showing a it. It seems to happen when weather is cold out (-5f to -15f that is was today).
The truck is always parked in a heated garage at night, and it does not make the noise when I first take it out, but after it has been outside for a while (whether or not it has running and driving the entire time) the noise eventually starts when it's this cold.
I just had it into Ford today, but they were unable to figure anything, and it goes back in tomorrow. I am just looking if anyone else had any insight I could possibly give them. Thanks in advance! Video below.
Whining
Uncles Non-whining 6.7L for reference:
Old 01-08-2019, 09:54 PM
danr1707
danr1707 is offline
danr1707 is starting off with a positive reputation.
Yup, I've had that. Almost seems like the belt is loose. But, once it warms a little, it goes away.
Old 01-08-2019, 09:59 PM
joshjohnson93
Hmm, mine take alot for it to warm up and go away. I have my high idle wired in to idle at 1100 rpms, which gets the engine easily up to operating temp, but it will still sit all day and squeal. It only seems to go away after semi aggressive driving, but then will return when the truck cools down a bit idling stationary again.
Old 01-08-2019, 10:19 PM
Bedlinedf250
Bedlinedf250 is offline
Bedlinedf250 is starting off with a positive reputation.
Mine does it also but only below 15 degrees or so. I thought maybe it was the engine calling for def. Because I've heard def freezes around that temp. It only does it for a few seconds on mine at first start up. I first experienced it while hunting and the temps were below 0. As I ran to the truck thinking there was something wrong, like maybe gelled fuel it stopped by the time I got there. I've probably experienced it 4-6 times in the last month or so. It doesn't happen every time or since the bad cold front has left.
Old 01-10-2019, 07:32 PM
joshjohnson93
Well just got the truck back from the dealer the second time, and all seems to be fixed. They replaced the belt and fan clutch, and when I picked the truck up it seemed to be cold enough outside, and no noise was to be heard.
Apparently on 2011-2016 6.7Ls the fan clutch was a known issue, but they were supposed to have been updated for 2017+, maybe I just got leftover parts lol.
Anyways we will have to see on the next extremely cold day, and if it's gone then I will be able to rest easy.
Old 01-11-2019, 12:49 AM
Truckie256's Avatar
Truckie256
Truckie256 is offline
Truckie256 is gaining momentum as a positive member of FTE.
Originally Posted by joshjohnson93 View Post
Hi all,
Whining https://youtu.be/uboUvro0f6Q
Uncles Non-whining 6.7L for reference: https://youtu.be/o8PAXfllLiA
Kinda sounds like the beginnings of my noise.... 2017 250 6.2L.... ended up being a Fan Clutch... said it was running full on all the time. only when cold starts (40F) and below
Old 01-11-2019, 01:01 AM
Imadentguy
Imadentguy is offline
Imadentguy is starting off with a positive reputation.
Yikes..... take it in
Old 01-11-2019, 08:44 PM
joshjohnson93
https://www.youtube.com/watch?v=CpkePCp0fE4&t=62s
It did turn out to be the fan clutch, they must be shared between 6.2 and 6.7. Thankfully I haven't heard it again so far, so hopefully the issue is solved.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
