Is this supposed to be straight? - Ford Truck Enthusiasts Forums
Old 01-08-2019, 12:55 PM
rtcapo
rtcapo is offline
rtcapo is starting off with a positive reputation.
I just got Gracie (short for Grace) back on the road. 1964 F100 6 Cylinder 223 ...and I'd like to deal with a shifting issue I'm having.
Getting into first is a problem.
Getting out of reverse is a problem.
Getting into reverse not a problem
2nd and 3rd are ok.
It was pointed out to me that this spacer (?) supposed to be straight. ( See photo )
A friend said I'm probably having shifting is because the motor mounts need to be replaced.
Any photos of what you have would be appreciated too.
Gracie 1964 F100 3 speed manual 223 6 Cylinder
Thanks
rtcapo
Old 01-08-2019, 01:13 PM
cosmofennema's Avatar
cosmofennema
cosmofennema is offline
cosmofennema is starting off with a positive reputation.
What is the nature of the problem?? Are you grinding gears??
In that case, the clutch may need adjustment.
Cosmo
Old 01-08-2019, 01:39 PM
rtcapo
rtcapo is offline
Grinds gears, not all the time.
Cosmo
When I can get into 1st, it's fine.
When I can't get into first, it grinds gears.
Sometimes it get's stuck 8n reverse, no grinding.
thanks
rtc
Old 01-08-2019, 02:17 PM
TA455HO's Avatar
TA455HO
TA455HO is offline
TA455HO has a good reputation on FTE.TA455HO has a good reputation on FTE.TA455HO has a good reputation on FTE.
Your picture has two green lines that look like you are outlining the Z-bar. The tube portion of the z-bar is not always straight. Sometimes they have a curve in them to clear the steering column, for example.
There are bushings on either end of the inside of the tube that can get worn out or crack and disintegrate, too. My 1966 probably slightly different so take with a grain of salt but these could be cause of some shifting troubles and might be worth at least a check.
I might be off as to what you are showing, too.
Chad
Old 01-08-2019, 02:22 PM
TA455HO's Avatar
TA455HO
TA455HO is offline
I might see what you are getting at - the Z-bar is maybe drooping a little bit toward the engine side? Motor mounts being shot might let the engine sink down some to where the Z-bar is running a little low on the inside. Anything like that which affects the geometry of the clutch linkage could be a culprit for grinding gears. The transmission shift linkage, linkage bushings, steering column condition, transmission mount and cab mounts can be other factors.
Chad
Old 01-08-2019, 07:26 PM
slabhunter
slabhunter is offline
slabhunter is starting off with a positive reputation.
Grace is lookin good!
Looks a lot like my W.B !
Old 01-08-2019, 07:40 PM
Highboy4x4's Avatar
Highboy4x4
Highboy4x4 is offline
Highboy4x4 is gaining momentum as a positive member of FTE.
I had the same problem with one of my 3spd trucks once and found out the cause was my cab mount had rusted out and was letting my cab sit too low causing too much pressure on my steering column. I replaced the cab mount and rubber bushings which raised my cab back to the factory specs. and it had no problems shifting after that.
Old 01-09-2019, 01:41 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Pic: Notice that the equalizer bar (7528) uses split bronze bushings (7517).
Old 01-09-2019, 05:13 PM
RattyFord's Avatar
RattyFord
RattyFord is offline
RattyFord is starting off with a positive reputation.
I'd try tightening aka elongating the part that pushes on the clutch fork (7521 in the diagram).
Old 01-11-2019, 07:57 AM
rtcapo
rtcapo is offline
I'm jealous of ur spare tire mount
She looks sweet!
The cut out rear fender to accept the spare tire was on my wish list for first time old truck. Gracie was just too good to pass by.
rtc
Old 01-11-2019, 08:03 AM
rtcapo
rtcapo is offline
much thanks
thanks for all the info n' great truck pix!
I was poking around under Gracie last night and looked at her motor mounts. Is this what a healthy motor mount looks like?
Old 01-11-2019, 04:39 PM
TheMonson
TheMonson is offline
TheMonson is starting off with a positive reputation.
I'm no expert but those look alright to me.
Old 01-11-2019, 04:47 PM
Tedster9's Avatar
Tedster9
Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Considering the truck is 55 years old those appear to be fairly new, in fact. "DC" may be Dennis Carpenter?
Old 01-11-2019, 08:15 PM
Gsf35099's Avatar
Gsf35099
Gsf35099 is offline
Gsf35099 is starting off with a positive reputation.
Yeah, those mounts look like they could have been replaced.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
