Just installed 37/11.5/20 on factory rims
I have slight rubbing at full turn. Here is my question.. Will 1.5 inch wheel spacers fit on the factory wheel studs? How long are our studs? (I dont need the bolts sticking out past the spacer) I know the 2 inch are no issue, but I'm not after that look.
I'm not a huge fan of using wheel spacers on trucks this heavy, that are designed for heavy towing. They are more suited for lightweight stuff like Jeeps. Having wheels with the proper offset for that sized tire is a better option, but definitely not the cheapest. By moving your wheels out with spacers, you are compounding an issue with ball joints and wheel bearings, and they will wear a lot faster than normal...
santacruzf250
17
09-21-2010 05:27 PM
