'STEER' me in the right direction
Perhaps somewhat of a rabbit trail, here, but is there any real value in converting from stock to a ram configuration for a 2wd F250 which spends its life as a road princess? My gut feeling is "non, not worth the extra money", but I'm willing to listen to alternative viewpoints.
Regarding WTOR and gear boxes, best to just call them.
Seeing how my buddies shop installs 3-5 of them a week and has for years and he had no chronic issues I’d say your claim is unfounded but you are certainly entitled to your opinion.
i just read their core policy and it seems reasonable to me, exactly what part are you taking issue with ?
Anyway, over the past 2 years there have been some serious problems with RedHead quality control. Although, a lot of people log on to a forum to complain and then never come back. So there is that....
Source - https://redheadsteeringgears.com/pro...spline-sector/
$356 for the steering gear
$200 for the core charge
Source - https://redheadsteeringgears.com/f-q/
Core charge refund reduced if any of the following take place...
- If a valuable and integral part of the steering gear is compromised to the point that it has to be replaced. - OK, so I can replace my steering gear if it is not broken, but if it is broken they keep part of my money?
- If the core that is sent back to us is a steering gear of lesser value we will reduce the refund accordingly. - What? Of course my steering gear is of lesser value, the RedHead gear is $360....
- If the core that is sent back to us is not original equipment we will likely need to reduce the refund. The reason for this is because some of the aftermarket steering gear companies may offer steering gears that are modified in a way that renders them unbuildable. - OK, so if my steering gear that hopefully isn't broken and hopefully is of the same value as RedHead sees fit, hopefully it is not a manufactured or aftermarket steering gear. Unbuildable? Well I guess that means that when all of the gears are bought, we are screwed...
$70 two way shipping.
So, for a grand total of $626.... Ya, $626 you might get out the door paying $426 IF, IF, IF your core meets their criteria... What a joke...
I would take the WTOR or Blue Top anyday instead of paying the kind of money that RedHead.
Just my opinion though and that is worth $0... In addition, I am wrong everyday, it happens...
The following users liked this post:
Redhead core policy is essentially the same as Bluetop.
perhaps Bluetop does a better job of explainging it.
“ if neither of these are included you may not get a core refund. Please refer to back of tag for more useful information for returning core. All cores returned after 30 days will be credited at 50% of the original core charge. Cores that are not OE or not identical to the gearbox we sent you will be credited at 25%. ($200 core charge = $50 credit). If we do not get back the correct core it changes our inventory requiring us to purchase another core to make up for the loss. If we do not get the correct one back then we cannot continue to circulate quality steering products.”
if you go on to read the rest of their policy they even do a good job of describing some of the aftermarket parts that may be in your box from previous rebuilders that do not meet their criteria for a core refund.
https://www.bluetopsteering.com/core-return-information
Don't let me interrupt your dance
I appreciate the feedback and personal experiences. Even if they are apples and oranges, I am debating whether to install the apple or the orange.
It's my daily. I dont do crazy rock crawling but it does need to hold up to the 35" tires on the deer lease for days when I dont have the side-by-side out there. Will blue top and redhead get the job done for years to come or am I better suited for the RAM set up?
IMHO putting 'just another' box on (don't care who's it is) is just a band aid and kicking the can down the road waiting for another failure.
600 bucks for rock solid steering and piece of mind, safety going down the road with loves ones on board etc = priceless
My truck has wide 35’s if you can’t turn the wheels at a standstill on dry pavement your pump could be worn or have air in the system. I used to just think the tires are too big until I just decided it was a weak pump. Very easy swap and it feels dirt cheap after doing the gearbox lol . The ram bar is deffinetly the best that’s what some of the 26ft trucks have I drive every now and then turning the wheel is effortless.
https://westtexasoffroad.wixsite.com...hydro-steering is the only way to go especially with you running bigger tires. The ram takes all the load off the box as one of the dance boys mentioned above
Good day pinky flying friends! ( <-- not tea cups)
My truck has had 35” tires for all but 2k miles of it’s life. The day after towing my boat home from AZ, the tie rod end at the pitman arm broke while I was backing the boat into its spot. When I looked at the failed part, I could see it had broken about half way through long before giving up completely. By adding the ram I halved the stress put on the box and pitman arm and now I can steer aired down at a dead stop with my foot hard on the brakes with one finger.
While this pic is of a failed sector shaft, the break is similar to my rod end break in that it was rusted half way through.
#28
I have gotten in contact with Justin at WOTR and will be placing my order hopefully today. Thanks everyone for helping me spend my money. I just knew I could count on you guys!
Justin says there are 2 ram options. He's out of the 1.5x6,7,8 but has the bigger 1.75x6,7,8. These numbers mean nothing to me right now. I'm about to go explore their FAQs on their website as recommended by Justin to figure out what suits me best but figured I'd ask akcooper, The Brad and anyone else running their stuff to see which one they are using.
#30
I enjoyed spectating the dance and always welcome you to the dance floor anytime you see fit.
You still have road feel, but it fells more like a rack an pinion with zero slop.
