Guess they’re getting old - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-05-2019, 06:51 PM
turbohunter's Avatar
turbohunter
turbohunter is online now
turbohunter has a spectacular reputation.turbohunter has a spectacular reputation.turbohunter has a spectacular reputation.turbohunter has a spectacular reputation.turbohunter has a spectacular reputation.turbohunter has a spectacular reputation.turbohunter has a spectacular reputation.turbohunter has a spectacular reputation.turbohunter has a spectacular reputation.turbohunter has a spectacular reputation.turbohunter has a spectacular reputation.
Hi all
I guess it happens to all of us but my truck (2008 6.4) is beginning to show it’s age.
You may remember I did a thread last summer on drilling out and replacing broken manifold bolts. Worlds worst job.
Well now I’ve got a few more things to add to the ”to do” list.
It’s recently started to drop oil on my driveway. Jumped under this morning and it’s coming from the rear main area.
Anyone have experience pulling a pan?
Today it started blowing white smoke on accel. Tail pipe is nice and dry. Have to check the coolant level when it cools. But I think that’s fine.
One hint is it just started today and today is rainy and cold here in LA (in the 50s)(yup that’s cold here). Could be intercooler?
Happy to yak with anyone with ideas or better yet, experience.
And no I don’t want to sell it and get a Ram. I love this truck.
Old 01-05-2019, 08:54 PM
DieselDenny
DieselDenny is offline
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Torque your pan bolts. I had a weep, did this and I'm dry as a bone so far. 5 out of the group were finger tight.
If I dared, I would drop them and put compound on them before retorq, but Give it a shot.
Denny
Old 01-05-2019, 09:47 PM
turbohunter
Thanks Denny I’ll give it a shot.
Old 01-05-2019, 11:39 PM
DieselDenny
Close attention to degas bottle zombie. JS
Old 01-05-2019, 11:52 PM
turbohunter
Yup, on it.
Old 01-06-2019, 12:19 AM
DieselDenny
My prob was just a coating behind/under the rear of the pan and nothing was on the ground. Retorqued as discussed, hosed it down perfectly, so far solved.
Denny
Old 01-06-2019, 10:31 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
Can you drop a pan in an installed engine?
if your getting smoke when cold and it’s not coolant....conn cr a scanner tool to the odbc port and see if you have any glow plug problems
other than that....work rocker tips and bent push rods will create smoke when cold. How’s you mpg. Mine was 8/9 highway before I did my rocker job and now it’s mid to high teens.
Old 01-06-2019, 12:03 PM
turbohunter
Yeah I don’t think it’s coolant either.
I just replaced a glow plug so I didn’t think to recheck that.
Last time I checked mileage it was 17 ish freeway. But haven’t checked in quite a while.
Old 01-06-2019, 12:14 PM
turbohunter
Just checked, it’s not throwing any codes.
Old 01-06-2019, 03:00 PM
turbohunter
Went under to check the leak.
Its not the pan. Traced it up to the glow plug harness on number 3 which is the plug that got replaced this summer.
Seems to be seated well. Guess it needs a new o ring.
Old 01-06-2019, 04:53 PM
turbohunter
One more note for the day.
Went out for a drive, no white smoke.
Today is warm and dry.
Just in case some have not seen it.
Ford TSB 11-2-2
https://f01.justanswer.com/bobover/0...-02-02_cac.pdf
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
