1963 Ford F-100 292 146 teeth flywheel
Old 01-05-2019, 01:19 PM
Vlasakmike
Vlasakmike is offline
Vlasakmike is starting off with a positive reputation.
Any help would be greatly appreciated as I'm having a hard time finding. Trying to replace the clutch in a 1963 Ford F100 292. The flywheel looks like it has cracks in it and I want to replace but I'm having a hard time locating. Does anybody know if there is there a replacement for the flywheel or any Replacements I can use
Old 01-05-2019, 01:27 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Measure the diameter of the flywheel and the bolt circle pattern where the pressure plate attaches, because...there are THREE different flywheels.
Ford also sold the ring gear by itself (it's the same 1954/64 223/262 I-6 & 239/256/272/292 Y block), but from what you typed, you need the whole enchilada.
Note: Please ask questions in the 1961/66 F100 and etc forum. This is the 1948/56 F1/F100 etc forum.
Old 01-05-2019, 01:43 PM
Smitty49's Avatar
Smitty49
Smitty49 is offline
Smitty49 has a great reputation on FTE.Smitty49 has a great reputation on FTE.Smitty49 has a great reputation on FTE.Smitty49 has a great reputation on FTE.Smitty49 has a great reputation on FTE.
If the Flywheel is good shape then the ring gear can be bought at C & G ford Parts-
https://cgfordparts.com/ufolder/ford...umber=EAA-6384
Old 01-05-2019, 05:07 PM
Vlasakmike
I will try measure and see what I can find out. Thank you, unfortunately I do need the whole thing
Old 01-07-2019, 06:44 PM
1960fordf350's Avatar
1960fordf350
1960fordf350 is offline
1960fordf350 has a good reputation on FTE.1960fordf350 has a good reputation on FTE.1960fordf350 has a good reputation on FTE.
Look up John Mummert. He sells Y Block parts. I think he sells an aluminum flywheel. I have a flywheel with a car clutch, it doesn't have the holes for a truck clutch. Or try Y Blocks forever site. Advertise in the classifieds. I' sure someone has what you need.
Old 01-07-2019, 07:06 PM
Vlasakmike
Thanks, I may try that. Right now I'm trying to find a shop to see if it's bad enough that it cannot be turned
Old 01-07-2019, 07:27 PM
Vlasakmike
Old 01-14-2019, 06:54 PM
Vlasakmike
Well I brought the flywheel to several shops and it seems like the opinion of all of them is to do nothing to it. It seems like it's not nearly as bad as I thought (me being a novice at these things). What a big relief hearing that from experts. I appreciate any input I received from The Forum as I will undoubtedly be asking questions again
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
