2011 Plastic to Metal Oil Pan Change Procedures
Just to make sure I'm doing this right - does anybody have the instructions Ford uses to swap the plastic oil pan on a 2011 F250 to the metal one.
I bought the oem replacement parts that were supposed to come with instructions, but didn't. I'm mainly concerned about torque values and setup/cure times of the silicone gasket material before torquing the bolts or adding oil.
You may want to shorten your oil change interval (e.g., to maybe 3-4 K) after you put the new oil pan in. The new RTV sometimes causes lots of Si to makes it's way into the oil, and Si is one of the most abrasive particles out there. Keep that silicon from floating around in your engine for too long. Not a real big deal either way, but if you care enough to replace the pan . . .
Mine is still working fine as well..2011, 157K miles..but I am very leery of that 1/4 turn drain plug..I can turn the darn thing by hand..if someone wanted to mess with my truck by opening that thing it would be pretty easy..
07F150Lariat5.4
2004 - 2008 F150
07-26-2018 01:30 PM
Crewcab Turbo
18
06-21-2013 01:21 PM
HD
48
01-04-2013 12:27 PM
