Ford part # for 3.5” Tapered Leaf Blocks
Hello all, I am in search of the oem rear leaf blocks from the early 2000s superduty trucks. Looking specifically for the 3.5” block, and am wondering if any of them are tapered for use on our excursions which are a 137” wheelbase, as the f250 blocks for the 137”WB truck are flat. I assume that is a 2wd model with a longer driveline so no need for a taper to prevent vibes. Has anyone found the correct ones and do you know which wheelbase truck they were from? I have rear B code springs that I’m looking to supplement with an additional 1.5” with these blocks.
Thanks!
Thanks!
Sorry I dont know the part #, but just want you to be careful. Tapered blocks are only needed if driveline geometry requires it.
Typically a lift with a cv type driveshaft will require a adjustment to pinion angle via a tapered block.
If driveshaft is not a cv type than typically no adjustment is required for pinion angle.
it best to measure the angles and than figure if a taper is needed based on the angles and driveshaft type.
To answer my own question and hopefully help out the next guy looking for this info...
99-01 F350 156”/158”/172” WB
3-5/8” Block Non-Tapered
F81Z-5598-DA
99-01 F350 137”/142” WB (What the Ex Needs)
3-5/8” Block with Taper (roughly 1/2” over 4” span)
F81Z-5598-GA (Left)
F81Z-5598-FA (Right)
F81Z-5598-DA
F81Z-5598-GA (Left)
cv type drive shaft requires the driveline to be straight inline with the pinion shaft so thst would be a diffrent taper.
Yes my excursion has a single cardan shaft with both outputs at the same angle currently, actually the pinion is about 1.5 degrees less to account for rise upon acceleration. The flat blocks should in theory keep this the same and shouldn’t induce any vibrations. They are only 1.5” taller than what I currently have in there.
f150light
13
08-31-2012 11:33 PM
viperbluelx
1999 to 2016 Super Duty
07-16-2007 10:26 AM
