Hollander interchange parts manuals
I have the below Hollander you mentioned that covers 1946 to 1956. It is helpful to a degree, but I don’t use it a lot. I think you’ll find that better sources are the Ford Chassis Catalogs. I have an original and the reprint of the Green Bible, as well as the original editions covering the 1948-1956 generations. They show there were parts carried over, primarily chassis related, from the 1947 era into the Bonus Built era. You might also look to find early Ford Obsoleted, Superceded, Interchange (OSI) manuals for these eras because they document part number changes that track an old part into the following era. Stu
Bonus Built era is the slogan Ford used to describe the 1948-1950 era. In practice it’s been stretched to include the 1951/1952 trucks.
Can be a lot of books if you want to track number changes. Ford was good at substituting some later part if it would do the job. Might not look the same, but the bean counters didn’t worry themselves with that. The Green Bible is the 1928 (iirc) to 1947 Chassis Catalog. The cover is green, but there is probably a cd version several vendors sell. Same goes for the 1948 to 1956 Catalog. If all you want is a quick and dirty way to look up parts on your pc, these are your answers. But please understand the 1948 to 1956 is based on the parts list from 1964. Numbers changed, and some parts simply disappeared in the later editions. Which is why I use the paper books. Ford of Canada published books for the Mercs, but I don’t know if a cd version is available. Sorta doubt it. Stu
IceCreamMan
05-27-2020 12:12 AM
69 Crewcab
12-01-2018 10:14 PM
keqwow
13
05-14-2011 09:05 AM
taylor90
04-07-2011 08:18 AM
