F350 rear tire pressure - Page 2 - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 01-04-2019, 11:33 AM
ccie7879
ccie7879 is online now
ccie7879 is starting off with a positive reputation.
Originally Posted by Tom N OH View Post
I run mine at 55 all the way around unless Iím towing heavy. Rides way better & tire wear is even across the tread on all 4. Used Forscan to drop TPMS to 45.
same here. I have on-board air if I want to increase pressure for any "no notice" tow
Old 01-04-2019, 11:37 AM
Redrockerstl55's Avatar
Redrockerstl55
Redrockerstl55 is offline
Redrockerstl55 has a good reputation on FTE.Redrockerstl55 has a good reputation on FTE.
Running 80 with no load all the time has the potential to wear the tire in the center faster.
I run 60 front and 65 rear when towing and I can feel a pretty significant difference in ride. I run 80 and 80 when towing.
I have never had a low pressure warning even when tire pressures are 55 and 60 when hit with a cold front heading into winter.
I have no made any adjustments to TPMS with Forscan.
Old 01-04-2019, 11:54 AM
N2dunz's Avatar
N2dunz
N2dunz is offline
N2dunz is gaining momentum as a positive member of FTE.
Originally Posted by wrvond View Post
First - I have looked, with no success, for an inflation chart that I can use. All the charts I can find are intended for commercial trucks with commercial tires. I would really appreciate a link to a non-commercial chart for my stock Michelin tires.
I run my tires at the specified 70 front and 65 rear. Just replaced all six at 85,000 miles. Remaining tread depth was 3mm which is above the legal limit, but too shallow for winter driving in my opinion.
Here ya go.
https://www.michelintruck.com/assets/pdf/MICHELINTruckDataBook_Jan2011.pdf
You will probably shoot holes in this, but I called Michelin tech support and even though it says Commercial, the tables for the LTX section applies to the tires on our trucks.
I told him what tire I had and on what truck and my intent and he said those tables applied.
Kudos for you to run 85k miles running those pressures.
I couldn't do it.
Old 01-04-2019, 11:56 AM
Redrockerstl55
Originally Posted by N2dunz View Post
Here ya go.
I couldn't do it.
FYI...That links says "page no found".
Old 01-04-2019, 12:01 PM
N2dunz's Avatar
N2dunz
N2dunz is offline
Geez.
How about google "Michelin Load Inflation Table" and then look around.
That is all I did.
Is there a way I can attach a PDF to a post? Maybe that will be easier?
Old 01-04-2019, 12:04 PM
Redrockerstl55
Geez.
That is all I did.
That's cool..I was just saying that link didn't work...that's it. Thanks.
Old 01-04-2019, 12:12 PM
Rockinfigs
Rockinfigs is offline
Rockinfigs is starting off with a positive reputation.
That's good to know.. Maybe il just lower my rear to 65 or 70 not towing
Old 01-04-2019, 12:13 PM
Redrockerstl55
This may be helpful:
275/65r20 for SRW
PSI/ Load
35/ 2080
40/ 2280
45/ 2475
50/ 2680
55/ 2850
60/ 3030
65/ 3195
70/ 3375
75/ 3540
80/ 3750
https://tirepressure.com/lt-metric-t...nflation-chart
Old 01-04-2019, 12:22 PM
mhoefer's Avatar
mhoefer
mhoefer is online now
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
I don’t get why your all running so high pressures on the front on a diesel. My door sticker says 60 psi front, cold, so I set the front at 60,the rear at 60. I have adjusted TPMS to 55 psi all way around. When you drive, these pressures go up due to heat in the tire. At -5 C, I see 64-65 psi all way around with sustained driving. But once the truck sits, they all go back down to 60 psi cold. I do this for tire wear as well, because the whole tire width is contacting the ground properly. Further, it improves winter traction. When I do load up the truck and pull trailer, I do air up the rears to 65-70 psi depending. Improved water, improved winter traction. I am running the new tires already Good Year Duratracs 295/65R18.
Old 01-04-2019, 12:56 PM
minke
minke is offline
minke is starting off with a positive reputation.
Here ya go.
I couldn't do it.
I don't know why, but using the link an "invisible" letter gets added after the .pdf.Instead use:I hope that the "invisible" letter doesn't return.
Old 01-04-2019, 01:07 PM
wrvond's Avatar
wrvond
wrvond is offline
wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.
Here ya go.
I couldn't do it.
Thanks - I have honestly never been able to find a table that wasn't for commercial tires. I even called Michelin once and got no help.
Even though your original link resulted in a 404, it did get me that critical piece of information: that a tire data book exists that contains the information I'm looking for.
I found a pdf tire data book at: Michelin Tire Data Book and it does, in fact, list Light Truck tires - specifically my LT 245/75R17E tires (among others).
I really don't know what the per axle curb weight of my truck is, but for fun took 7680 lbs and distributed 2/3 to the front and 1/3 to the rear axle (DRW). 5120 lbs. front and 2560 rear would indicate 60 psi on each of the front tires and 35 psi on each of the four rear tires (the minimum indicated on the chart).
If I had never seen the Tire and Loading Information label on my truck (70 front/ 65 rear), I know I'd accept this as perfectly reasonable.
Because I tow different weight campers most of the time, and because the inner rears are so hard to reach, I'm not likely to change my inflation pressures any time soon, but I did learn something today.
Reps sent!
Old 01-04-2019, 01:09 PM
Redrockerstl55
Use this link. Look up your tire size and you will know what to set your pressure at based on load.
  #28
Old 01-04-2019, 01:35 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
As near as I can tell, the inflation tables are generic, set by TRA (Tire and Rim Association). I've used the inflation tables published on the Toyo website in the past. The doc specifically says the numbers came from TRA. The doc can be found attached to this post or using this URL: https://www.toyotires.com/media/2125...s_20170203.pdf
  #29
Old 01-04-2019, 03:03 PM
rcinlaveen
rcinlaveen is online now
rcinlaveen is starting off with a positive reputation.
55 front, 45 rear when empty. I just push the "OK" button once in a while - no big deal.
  #30
Old 01-04-2019, 03:27 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.
Same here. I will get around to changing it with Forscan when I'm feeling less lazy though
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
