I haven’t used this one, but it appears to be the most original style wiring. The description says that new original style connectors and terminals are part of the kit, but I assume you still need to splice them in after you cut the wire to length. I plan on using this when I want open my wallet. It has pretty hefty price tag. This is the cheapest price I’ve seen on this one, a little more on eBay, Summit Racing an other online stores.
Hi guy's, did some more work on the truck. Needed to drop the front tierod end down below the springs and the previous owner had these crazy welded up rod ends. My machinest buddy took the lead on this and made these really nice machined extentions that screw on then clamp. Also need a adjustable brake pedal rod, he did that too.
Reason: left out script.
Worked on the interior next. Mocked up a console and kick panels out of cardboard, then transfered to wood. After cutting and fitting them, sanded and preped, then sprayed them with bedliner! Looks pretty good.
