solvent pop
Old Sep 28, 2003 | 12:41 PM
learpilot's Avatar
learpilot
solvent pop
Is there anyone who can give me indepth advice concerning a paint job gone bad. I would like to contact some in person to discuss my problem, Thanks
Old Sep 28, 2003 | 06:46 PM
joners's Avatar
joners
What do you need to know?
Old Sep 29, 2003 | 11:02 AM
learpilot's Avatar
learpilot
Re: solvent pop
I need to know what caused it , can it be caused by the previous paint job,if the proper prep was not done? Shouldn't a top coat of primer and paint have covered it if it was in the orginal paint. If you will provide a number i will be glad to call and discuss, Thanks Jerry
Old Sep 29, 2003 | 11:16 AM
Huntsman's Avatar
Huntsman
Solvent Pop as I understand it, is improper 'curing' time between coats of paint. The solvents are forced to escape through the next layor causing tiny holes in the final coat.
That is one reason for chosing the correct hardener based on expected temperature during the painting process.
Old Sep 29, 2003 | 07:12 PM
jwcnj45's Avatar
jwcnj45
Solvent pop can come from a previous paint job. In many cases the solvent pop will not become visable until the clear coat is applied and by then it is too late. It is caused usually through too heavy a coat of material or improper flash time between coats. In some cases with catalized primers, if the primer is heated between coats to dry it faster solvent pop will occur. I encounter these problems from time to time in my work and it can be a frustrating problem at times. Sometimes the pop can be buried under a heavier coat of clear or primer. If this doesn't work a skin coat of finish plastic can be applied over the surface after it is sanded and then primed and repainted. Your best method of repair is to strip the finish and start over, although this may be impracticle and not an option in your case.
