Heated seat and mirror not Working 15 F250
I have a 2015 F250 6.7 diesel that had a burnt harness under the driver seat. The harness was fixed and now everything works again other than the driver side heated seat cannot be controlled by the screen and the mirrors can only go out and down not the other ways. they can also fold and extend. the heated seat however will go on when you remote start the truck but you cannot manually control from the screen. Is there another module that I need to replace...the whole seat was replaced do to the fire and I think the seat module is fine. Also a couple other tips, when I had a guy plug a scanner into the truck he could move the mirrors probably and turn the seat on!!!!so I'm super comdused! confused! Also when u hit the button that's suppose to turn the seat on the passenger side module makes a click....i understand that these truck wiring is all wired together so I'm assuming the switch current runs through the pass sest???!?!?!
Any help would be greatly appreciated!!!. Thanks ken
You might can program them or check their programming with FORScan with an OBDII adapter. Maybe even reload the As-Built data for them with FORScan. Otherwise, you would need to go to a dealer to have them reload the VIN/Truck's As Built data for the modules.
DSM - 744
DCSM - 776
https://docs.google.com/spreadsheets...#gid=408622689
As-Built data can be found here for your VIN...
Ford As-Built Data
DSM - 744
DCSM - 776
Ford As-Built Data
DSM - 744
DCSM - 776
Ford As-Built Data
DSM - 744
DCSM - 776
Ford As-Built Data
CarbonClear
Electrical Systems/Wiring
03-15-2011 09:39 PM
