2019 Annual B.S. Thread!
#331
@Sparky83 got it, any room to weld a bung on the outside?
which is why i was thinking of just drilling and tapping then adding a nut on the inside for added strength....
#332
yup... but cant get the pipe out to get it to my welder... which was what i tried to do today... (really wish i could figure out how yall do that tagging thing in the posts)...
Now I understand your issue more.
#334
yeah kinda why i wish my equipment was gas powered and not "you gotta have an outlet within 2 ft to power me"... ntm the short leads are just as annoying...
right now the trucks about 100 ft away from where the welder is... in order to get it close enough i would need it literally right against the back door for the garage...
#336
mig.... my stick welder has the same issue.... but dont have any Stainless rods for the stick... only got stainless wire for the mig....
#337
Well one option is to find a shop that does exhaust system workand get everything all back together and running.
Then take it over and have them weld tjhe bung on for you.
#338
i just look at something like that as someone taking their car in and telling them to put air in their tires even though they have a perfectly good air compressor sitting right next to their vehicle... plus once its back together i wouldnt be able to get to where the bung would need to be... supposed to be within 2 inches of the turbo outlet... would be nice if i could just get that stupid pipe out....
#339
Received 3,545 Likes
on
@Sparky83
Shawn, If you remove the cross member on the transmission can you lower the back of the motor and get the pipe out? Just a thought as I had to do that to install a larger pipe on my 97' with a 7.3. Maybe even remove one of the motor mounts? I know it's getting into a lot of work but beats having someone else air up your tires. LOL Just watch the front of the motor that you don't damage the radiator with the fan.
Tim
Tim
#340
@Sparky83
Tim
Tim
#341
on
Got it. So it sounds like you have a plan, with installing the Pyro with a nut on the inside of the pipe. I wonder if doing that would cause the tip of the pyro to be to far inside the pipe? And also I wonder about having the nut on the inside if it wouldn't cause more turbulence and somewhat of a restriction?
#342
id try the band clamp one except for the band is designed for smaller pipes than the diameter of diesel pipes...
Temp probe...
im more worried about the nut vibrating off and finding its way back to the turbo... even though its called a lock nut i kinda worry about it doing that... its not a nylon one..
#343
on
I didn't realize they actually make something like that. Cool! That looks like a great plan! You'd be better off with the little nut they provide, then a nylon locknut.
#344
the little nut id be buying from another company.. kit didnt come with a nut...
if they were nylon i know that stuff would melt in the heat of the exhaust... with it not having that and just being called a lock nut im still worried itd vibrate off..
#345
Second pain in the *** idea.
What about dropping one of the motor mounts? I know that is going to be a lot of juggling.
However it might give you the needed space. Your trying to do what I was almost going to do.
