COOLANT LEAK DRIVERS SIDE REAR TOP
First, Happy New Year to all. I have occasionally visited here since buying my truck in 02. Since then it has been pretty much built up, rebuilt and repaired on a regular basis but still going strong much of the time. Todays issue appears to be a coolant leak on the drivers side top rear under the intake and thought I would scope it here prior to removing stuff as sometimes these repairs are a little over my head.
Top like near the valley or top like near the oil cooler? The oil cooler is really the only coolant moving part on the drivers side of the engine. Going toward the front of the engine you have the water pump and going under the engine you have plugs and heater...
Pictures of the leaking location would help, but I am betting your cooler is leaking. It is not typically the coolant leaking from there, but it does happen.
No, I have a large S&B sealed airbox connected by a large hose structure connecting to a large Garrett turbo. Under the connecting structure I noticed steam eminating from there yesterday after driving a short while. Is there a hose there? I thought I may have seen a disconnected hose perhaps beneath but I cant really tell or take pictures without removing the whole S&B deal.
Are you sure it is coolant?
As Sous said, no coolant is routed up top back there. The only thing on top is the heater hose in front that goes down the passenger side and the upper hose that goes from the thermostat housing in front to the radiator.
Could your doghouse be leaking and it's coming from the CCV?
Well it just looked like steam emanating and the coolant reservoir was down a few inches so that's what I assumed it to be. I don't know what the doghouse is. Yesterday, he check engine blinked on really briefly and then never came on again. Hope its nothing too serious. I can't seem to spend enough money on this thing. Like the guy with the bucks bazooka. But I need it for various things like fifth wheel towing, hauling, 4x4.
Well believe it or not it was just the CCV not connected into the cold air feed. I was working on something else a while ago, disassembled it and didn't realize the CCV became separated. Thanks for not calling me a ******* at least to my virtual face. Everyone has always been fairly gracious at this forum and much appreciated being a nonmechanically talented dude. I still need to find out where my coolant is going though. That would seem to indicate a leak somewhere.
Glad it was a free and easy fix! Those are the best kind.
We're a pretty easy going bunch here in the 99-03 forum and are happy to help.
