Need Help! - 2019 F250 Factory Prep Package Install - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Towing Forum > Fifth Wheel & Gooseneck RV Towing
Reload this Page >
Old 12-30-2018, 04:39 AM
Jonathan Mills's Avatar
Jonathan Mills
Jonathan Mills is offline
Jonathan Mills is starting off with a positive reputation.
Newbie here and need some help from my fellow Superduty owners. 2019 F250 Factory Prep Package Install.
Finally found a used Factory Prep Package, butís itís missing the hardware and instructions. Can someone please provide a PDF copy of the install instructions? Also need part numbers for the hardware and wiring harness. Anyone in the Northwest Georgia area that might be interested in helping install?
Old 12-30-2018, 11:18 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
I never did find a ford instructions guide
i used this Reese clone to get measurements
Old 12-30-2018, 11:10 PM
firedaniel
firedaniel is offline
firedaniel is gaining momentum as a positive member of FTE.
It’s the same as the Reese. I put one on my 06. It’s exactly the same hitch setup
Old 12-31-2018, 12:34 AM
speakerfritz
The ford hitch I have is a 1 piece unit that you could drive a tank over
Old 01-02-2019, 02:43 PM
thomabb's Avatar
thomabb
thomabb is offline
thomabb is a splendid one to beholdthomabb is a splendid one to beholdthomabb is a splendid one to beholdthomabb is a splendid one to beholdthomabb is a splendid one to beholdthomabb is a splendid one to behold
It is a common misconception that the Ford and Reese underbed setup is the same. They are compatible with each other, but they are not the same. Reese does not make the Ford underbed system.
Old 02-04-2019, 06:44 AM
bjones211
bjones211 is offline
bjones211 is starting off with a positive reputation.
Did you ever get the install instructions? I can scan and email them to you if still needed. Will be installing mine this week.
Old 02-04-2019, 10:28 AM
ATC_F350
ATC_F350 is offline
ATC_F350 is starting off with a positive reputation.
For those installing these kits, Curts has their puck ball kit with a $75 rebate currently. You can get it for about $120 after rebate.
Old 02-05-2019, 07:02 AM
Gwilkrrs
Gwilkrrs is offline
Gwilkrrs is gaining momentum as a positive member of FTE.Gwilkrrs is gaining momentum as a positive member of FTE.
congrats on scoring a used hitch-
I have been on "wait" for a new one and searching for used..................
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
