bringing chrome back to life - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > General > Garage & Workshop
Reload this Page >
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 12-29-2018, 05:33 PM
rortiz156
rortiz156 is offline
rortiz156 is starting off with a positive reputation.
Does anybody have any good methods of restoring aluminum/chrome, particularly a diamond plated tool box and bed liner? I've tried California customs deoxidizer and polish but it didn't do much for the time I spent and the really bad spots. Want it to shine
Old 12-30-2018, 11:05 AM
F350 1990's Avatar
F350 1990
F350 1990 is offline
F350 1990 is gaining momentum as a positive member of FTE.
You have a range of chemical, abrasive options if aluminum -- not sure about chrome given the limited amount of material they use these days. In the past you could remove some of the upper layers and still get "shine" but lately that's not the case....
Old 12-31-2018, 06:48 AM
tjc transport's Avatar
tjc transport
tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
for aluminum, a muriatic acid solution works great to beak down the crud, then wash off and polish/wax.
for chrome, coca cola soda and aluminum foil, then wash off and a heavy coat of wax once dry.
Old 12-31-2018, 06:49 PM
rortiz156
Thanks for the tips Ill try muriatic acid got and some laying around and haven't gone with the foil approach either.
Old 12-31-2018, 07:07 PM
tjc transport
i ain't rite
when doing the muriatic acid, you only want a very little bit. if i remember correctly, .05% for aluminum. spray it on and rub with a soft bristle brush. when it starts to change to a dark color, wash off with a lot of water.
if you let it sit on till it turns black, it will stain the aluminum.
Old 01-01-2019, 04:30 PM
PupnDuck
PupnDuck is offline
PupnDuck has a very good reputation on FTE.PupnDuck has a very good reputation on FTE.PupnDuck has a very good reputation on FTE.
Just realize that you'll never restore to original appearance. Corrosion and oxidation of aluminum is just that - metal that isn't there any more. You can remove the oxidation and other assorted crud but there's nothing you can do about the pitting.
Old 01-07-2019, 12:39 PM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold
This prompted me to take care of the odds and ends of sockets, wanted to clean them up and knock off the little bit of rust. So I bought a gallon of evapo-rust. It is available at most auto parts stores. It took off the rust without pitting or doing other damage to the chrome. After the soak, I rinsed them off in water, according to the instructions. Finally I used WD-40 corrosion inhibitor on the tools and put them back in the chest.
Old 02-02-2019, 07:46 PM
jade79
jade79 is offline
jade79 is gaining momentum as a positive member of FTE.
I've had good luck with an SOS pad on chrome, used lightly. The water beads up when rinsed off so it seems to leave a temporary protective coating too.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
