Wiring melting
Hi guys! My name is Rob and I’m new to FTE. I recently bought a 1970 F250 Camper Special with the original 360 and I’m still trying to work my way through it. I heard the truck turning over and starting when I went to pick it up but once I get home and put a new battery in it, things got interesting. I found that someone cobbled together a wiring patch that is now melting and smoking as soon as the battery gets connected. I’ve already replaced the starter solenoid and traced it as best as I can. It seems to be leading into a bundle that lands on the back of the altenator? I put in a few pictures so you guys can see what I’m talking about. Can anyone tell me if I’m right if this is the altenator ground? Does anyone know where I can get just this harness? I’m trying to do this project as a daily and a slow rebuild and can’t afford the $700 LMC wants for an entire trucks worth of wiring. Any advice would be great!
The starter relay solenoid gets the ground path it needs through the bracket and hardware attaching it to the inner fender. This is important. Nixon was president the last time that was serviced! One of the starter/battery cables looks to be original, genuine 1970 vintage, stiff as roadkill squirrel. The posts and connecting hardware and everything are pretty corroded. It won't matter what size alternator is installed, it will be practically crippled by high resistance electrical connections. Every single connection throughout taken together adds up, it makes a tremendous difference in engine starting, battery charging and ignition current available to the spark plugs.
Everybody is probably familiar with battery post corrosion, but they are all important. Not trying to beat up on you personally or anything, it's just that picture is a perfect illustration of how difficult the automotive electrical environment is! It's amazing they work at all after 50 years. Recommend purchasing a complete set of heavy duty gauge cables, and clean the connections to bare shiny steel at block, frame, firewall, etc., and tighten securely. $10 says the engine will even warm up quicker, everything doesn't need to be all purty in there necessarily but it does pay to keep those electrons happy in the wires.
Additional GRD to frame- next to VIN on frame-
Extra GRDs from inner fender to radiator support, then one to the voltage reg and other wire to headlight frame
Also, why not repair the defective grounds that the vehicle came with that have worked for 50 years? A voltage drop test will locate good and bad grounds if any. There is no need to re-engineer a system that has worked well, just fix what's there.
I also went with a larger size positive cable from the battery to the starter solinoid, and down to the starter.
Notice the black GRD wire on the mounting bolt- on the inner fender.
What do they say? Go big or go home!
As part of my 81 F100 flare side (300 six) rebuild I replace all the battery cables and I also went bigger than what the truck had from the factory.
I even had to solider the frame tab on the cable like the factory had for the ground.
Tab bolted to frame like factory. It is the cable on the right, the left is an insulated cable holder for the POS to the starter.
My truck also has a ground wire (10 ga) from motor to firewall and a braided cable from firewall to hood, all factory.
When I get the bed mounted I will add a ground wire from frame to bed just for good measure.
Dave ----
Now you cant use a normal fuse as it will blow when the load is added to it where the fuse link is a "time delay" fuse.
When you send power thru the link it starts higher than a fuse can handle then comes down to a normal level.
You can get new links at the local parts stores in the help area. Think they have a crimp butt connector on them already just use the right tool to make the crimp.
I would remove the tape from the wires to make sure all is good.
I would then get a new link and run it to the starter relay (where that other wire is) and to the wire it should go to from the ALT if that is where it goes.
Go over all the grounds and I would replace all the battery cables for piece of mind.
If the battery is good you should be good to go.
Dave ----
Tough to tell from a pic, that looks like 00 is the smaller stuff. The garden hose size has to be larger than that. For those that don't know, in AWG the smaller the # the larger the diameter. 8,4,2,1... then 0, 00, 0000 is larger yet.
Dave ----
