Grandad's 68 f100 build - Ford Truck Enthusiasts Forums
Old 12-27-2018, 09:29 PM
Wideflange
Wideflange is offline
Wideflange is starting off with a positive reputation.
Started my build recently. Started out as a bone stock, 68 360 f100 LB. This was the only new car my grand parents ever owned. My dad had done some upkeep and a few resto's.
The plan:
Swap front end with CV
DIsc all around
Refresh rear end currently 9" 3.50
Lower rear stance
Gut interior and clean, dynamat top to bottom
New headliner and visors
New old look stereo
New dash cover
Tilt wheel
Ditch the 3 speed manual, TCI Streefighter combo C6 to replace it
Powerplant:
416 Stroker- 390 w 428 crank
S Code intake manifold for 4 barrel Holley
268h comp cam kit
WIndage tray
HV oil system
HiFire Pertronix distributor
Block coming back from machine shop. 428 CJ crank balanced, prepped and polished
Needed to add a brace to the cheapo harbor freight stand.
Also added a set of large casters so I could move this pig around easier
Mockup
Original heads rebuilt, seats and guides installed
Went with Eagle H-beam connecting rods
Silvolite dished pistons should give around 9.7:1 with an 041 gasket
Degee-ing cam
Did not have to do any clearance work
Going with the earlier larger thermostat
That's it for now. I already have the front end stripped, rear end reset with lowering kit. Waiting on some free time to grab a CV donor..
Old 12-28-2018, 09:04 AM
Fat Diesel's Avatar
Fat Diesel
Fat Diesel is offline
Fat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud of
Awesome! It's a lot of fun to build an engine like that. It's going to turn out great.
Old 12-28-2018, 11:56 AM
Nighteyez's Avatar
Nighteyez
Nighteyez is offline
Nighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputation
Never got a chance to do a total build like that. I am sure it will be an awesome feeling of satisfaction when it is done.
Jim
Old 12-28-2018, 07:37 PM
Wideflange
Thanks guys.
Here's a couple more shots.
Grabbed the cv front end at the local tweak n pull.
after a quick pressure wash at home.
Interior coming out
Roof brace was whammoed
Brace straightened up and dynamat going on
Waiting on a couple parts from Summit to finish motor. Then it's on the chassis
Old 12-29-2018, 01:32 PM
olfordsnstone's Avatar
olfordsnstone
olfordsnstone is offline
olfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to behold
Thanks for sharing your build. Fun! Even if only vicariously experienced.
Old 12-29-2018, 11:30 PM
Nighteyez's Avatar
Nighteyez
Looking good so far.
Jim
Old 12-31-2018, 12:23 PM
Wideflange
Digging out the old seam sealer. Most of it was rotted away.
I'm lucky that there is no rot in the cab corners at all.
Got the rear disc kits installed. Had to get the axle flanges turned to 6.25 for the rotors
New brake lines
Old 12-31-2018, 01:51 PM
Nighteyez's Avatar
Nighteyez
Is Grand dad still around to see this?
Jim
Old 12-31-2018, 02:34 PM
Wideflange
Jim
No unfortunately he passed in '91 I wish he was around if not for anything but to tell me how I'm doing it all wrong
Old 12-31-2018, 02:46 PM
Nighteyez's Avatar
Nighteyez
That is too bad. But you can keep the legacy going.
Jim
Old 01-31-2019, 03:43 PM
Wideflange
Making slow progress on the cv front frame work.
Sleeved with chrome moly tube, plated lower frame rail, ground flat and getting ready for upper rail plates. Re-worked trailing arm bushings too.
Lot's of cleanup work to do yet and paint of course.
Old 01-31-2019, 04:45 PM
Nighteyez's Avatar
Nighteyez
Looking good.
Jim
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
