Things I donít like about forscan - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-27-2018, 02:45 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
Well I bought the hardware and bought the software .
Thereís a kazillion bits of info forscan will give you....unfortunately....no egt1, egt2, egt3
it will tell you historical dpf stuff, but not when the next default regen will occur
a lot of the readings are in scientific terms....instead of psi for things like ebp, itís in bar time something else
its more informative than a code reader...but not a replacement for ids
I did find some accessory faults that do not show up on a code scanner so I need to hunt those down.
not too useful on a 6.4
the 6.7 folks are having a blast with it
Old 12-27-2018, 04:52 PM
speakerfritz
​​​​​​​I looked again and found egt1,egt2,egt3.
Old 12-28-2018, 12:07 PM
DieselDenny
DieselDenny is offline
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
I was going to tell you but...........
That's how I found my high idle was associated with no. 3 EGT sensor . When it gave up, my RPM's at idle were 950. After replacement it dropped back to 650. Alot more manageble in tight parking.
Denny
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
