Rim size for 255/70r15
Hello. I am ready to put new wheels on my 56. I am going with 255/70/15 rear and 235/70/15 fronts. Should I go with 15x8 and 15x7, or 15x7 and 15x6? I like some sidewall bulge but don't want it to look odd. Looking for advice from anyone who has been down this road. Thanks!
on
I ran a 255/70 R15 tire on the rear of my 32 Ford for years. It was mounted on a 15 x 7 wheel. Unless you have power steering I would run a smaller and taller tire up front...more like a 215/75 R15 for easier steering. The wide tires up front have a tendency to do the steering for you due to the ruts in the pavement left by large trucks.
I went with rear wheel- 15x8 with 4.5" backspacing and Crager SS rims. rear tire- 255x70 R15 Firestone. There is 11" of clearance in the rear wheel fender wells. A 10" wide tire would have appropriately a 1/2 ' to spare on each side if center correctly. Rear axle width will dictate backspacing. My rear axle came from a 91 Explorer.
Received 4,132 Likes
on
I have about the same set-up but with 16 inch wheels. So the tire bulge will be different, but not by much. A lot depends on tire manufacturer. I went with the less bulge approach.
If you want to have all the same rims, the 7 inch is best.
Otherwise 7 inch front, 8 inch rear is a good choice for staying within specs and minimizing tire bulge.
Work out backspacing to make sure that you get the look you want (and of course fit properly).
https://www.ford-trucks.com/forums/1...thread-16.html
apachetech
03-06-2015 06:50 PM
49willard
11-27-2007 02:40 PM
Low55
03-27-2006 07:15 PM
shipfitter1966
02-13-2006 06:07 PM
