How to adjust pinbox for bed rail clearance? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Towing Forum > Fifth Wheel & Gooseneck RV Towing
Reload this Page >
Old 12-22-2018, 05:30 PM
191124x7's Avatar
191124x7
191124x7 is offline
191124x7 is gaining momentum as a positive member of FTE.
looking at the photo, I canít see any way to add an inch of height to my bed rail clearance. Is this even adjustable?
Old 12-22-2018, 10:55 PM
Army RET's Avatar
Army RET
Army RET is online now
Army RET is a splendid one to beholdArmy RET is a splendid one to beholdArmy RET is a splendid one to beholdArmy RET is a splendid one to beholdArmy RET is a splendid one to beholdArmy RET is a splendid one to behold
The bed mounted hitch itself is adjustable up/down (unless it's already maxed out).
Incidentally, 9mm 24x7.
Old 12-22-2018, 11:42 PM
HRTKD's Avatar
HRTKD
HRTKD is online now
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
LOL! I just got it. Me too on the 9mm.
Old 12-23-2018, 10:09 AM
Super Duty DJ's Avatar
Super Duty DJ
Super Duty DJ is offline
Super Duty DJ is starting off with a positive reputation.
Take a look on the inside edge of the pinbox to see if there is a third hole in the back that would line up if you dropped the whole thing an inch. You may have to move that third bolt from the front set of holes to the back, but may still be able to have five bolts per side and get the adjustment you are looking for. Also, you may be able to do some searching to see if all five bolts are required on each side to maintain the appropriate weight rating on the pin box.
Old 12-23-2018, 10:34 AM
xxxsherpa
xxxsherpa is online now
xxxsherpa is gaining momentum as a positive member of FTE.xxxsherpa is gaining momentum as a positive member of FTE.
I'm going to guess .45.
Old 12-23-2018, 10:37 AM
191124x7's Avatar
191124x7
191124x7 is offline
Ah Ha! Ok. Thank you!
Old 12-23-2018, 10:48 AM
mwheue
mwheue is offline
mwheue is starting off with a positive reputation.
Old 12-23-2018, 02:16 PM
191124x7's Avatar
191124x7
191124x7 is offline
Originally Posted by mwheue View Post
Thanks. Most likely where Iíll end up. My hitch is as high as it goes and I donít want to lower the truck.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
