99 F350 V10 california rebuild upgrade
I have been struggling to find the problem on my V10 that starts and runs fine for 10 minutes / until t -stat opens then engine temp and oil temp light come on. Engine goes into limp mode. Coolant overflows. Turning engine off for less than a minute and then restarting , the engine runs fine until next shut down and cool off. No coolant in the oil , no visible coolant in the exhaust .no oil in the coolnt . Have taken to two mechanics they both have come up with must be a hairline crack in head. Reported hydrocarbon in the coolnt. And very slow leak down in coolant system. The engine currently has 170K miles. Around 60 K had spark plug threads pull out had heads pulled and brass inserts were installed before I knew about repair in place fix.
Now assuming I need to replace at least one head. I figured I would try and and do the best I can since I plan on keep in the truck forever. Which to me means replacing both heads and since replacing both heads should rebuild block as well.
From the posts I have read going with 99 non PI block with 2003 + spark plug improved heads and matching intake plus a special tune for higher compression would be my best bang for buck repair upgrade.
I have asked my mechanic to quote me on this. And first suggestion back from him was to use corresponding piston in the block to match heads and then no special tune program would be needed. I do have a concern over the special tune due to not knowing if that will affect california smog checks.
Sorry for the long post. What is the best way to go for my situation.
To my knowledge of ca snog checks is that you can upgrade to newer year engines and the emission must match the way it was sold by ford the the year of engine in truck. IE: 99 truck, 2003 engine, than 2003 emission standards. You can NOT go backwards IE: 2003 truck with a 99 engine and emissions. Put simply in california just figure that the enigne and emissions system is one piece.
Now if the emissions were the same for both years than a direct swap is possible.
I dont know the v10 well enough to say how ford built them and the model year differences if any. This is somthing other members could chime in on.
Performance stats upgrade to V10 PI heads
Thank you that helps with the smog info.
Anyone know if there would need to be any change 99 non PI factory tuning if PI Heads installed along with corresponding pistons that produce year 99 non PI compreession.
Or is is there a lot of benefit to the higher compression set-up?
Just to clarify....is the 60K correct on spark plug threads going south on you....or did you mean 160K?
