Full Retrofit Headlights DIY
#77
Naw didn't take any after i was done. For the bottom halogen bulb hole i bought grommets from ACE and trimmed them down to fit in the hole, ran my LED cube light wiring though the grommet, sealed with RTV. For the top, the projector comes with rubber washers and i used that to seal the projector to the housing. I re installed the OEM dust covers on both the top and bottom spots. RTV is solid for touchups IMO, i know guys who have only used RTV to fully reseal headlights and never had issues.
#79
#81
#83
#85
quad output is gonna be awesome. The white bowl will help give it depth, should come out great.
excited to see this! Be firm but gentle with the lens when separating. i think i twisted/got one side outta the channel to far and it caused my one lens to have a bunch of tiny cracks i didn't see until it was reinstalled and in the sunlight.
The headlight height adjuster assembly can be cooked in the oven, don't worry about trying to remove that. it was fine in the 280 degree bake cycles.
#86
#87
Smart...it was nice having an extra set to run so i didn't have to rush it over a weekend. Let me know how that stuff works for splitting the lens apart. Yesterday i realized i can get to the driver side bulb without removing anything. that'll be handy for when i have time to tweak the projector just a bit. Should be able to spin it just a few degrees to get it perfectly straight. i think passenger side i can also twist once i remove the plastic cover that spans the front end.
#88
#90
