How concerned do I need to be with 5" clearance? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Towing Forum > Fifth Wheel & Gooseneck RV Towing
Reload this Page >
Old 12-19-2018, 08:37 PM
191124x7's Avatar
191124x7
191124x7 is offline
191124x7 is gaining momentum as a positive member of FTE.
So in my current configuration I'm completely level. Like perfectly level. The top of my front A/C is pretty darn close to 13'6".
I've got a hair under 6" of clearance on the sides... truck bed level, fiver level, parallel.
But if you look at that little flair at the back center of the tailgate... how it turns up just a little bit... at that point it's closer to 5".
1. I don't want to raise my Reese Elite 25k. it barely fits under the backflip as it is.
2. I don't see a way to adjust the pin box. Does anybody know if my pin box is adjustable?
3. I hate the sound of crunching fiberglass... I've already heard it once when I lowered a nosecap onto the bedrails of a previous truck -- don't want to hear it again.
What I've love to hear is that my configuration is fine. If not, that my pin box is adjustable and has room...and hopefully I won't end up taller than 13'6".
Any / all suggestions welcome and appreciated.
Thanks!
Old 12-19-2018, 09:39 PM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Paw's 150 Lariat is offline
Paw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to behold
Mine is the same way...about 5 inches from the rise in the tailgate center and close to 7 inches on the sides. Raised my hitch to the highest setting. Only time I got close was when I had to detour off the highway and make a u- turn in a powerline right of way...close to the top on the truck bed and close to the front legs and frame rail going up an incline and back on the highway. My driveway has a slight incline to where its level under my RV cover. 14' height on the front of the cover and it clears by about 8 inches.
Old 12-19-2018, 09:51 PM
Paw's 150 Lariat
Only pic with this trailer hooked up showing side clearance. Needed every inch of it having to make the offroad detour.
Old 12-20-2018, 07:54 AM
191124x7's Avatar
191124x7
191124x7 is offline
Man, that is an incredible set up for home storage! I would have to move to so something like that; but maybe some day. Iím gonna save those pics.
Old 12-20-2018, 07:56 AM
191124x7's Avatar
191124x7
191124x7 is offline
Thanks for this. I think Iím going to measure the exact height; and if I have an inch try to raise the pin box...if not just be really careful.
Old 12-20-2018, 10:05 AM
Paw's 150 Lariat
Looks like I have the same Roto Flex pinbox. My Curt Q20 barely clears my bed cover at the highest setting. Easier for me to raise the hitch then the pinbox and the truck sits level enough for me. Put about 5K miles on the rig since March. Had a Fuzion toyhauler for 3-1/2 yrs before the Solitude the wife wanted. The 17 and up side rails on the Fords are about 2 inches higher then the previous models so this can be a potential problem.
Old 12-20-2018, 07:59 PM
First Dually
First Dually is offline
First Dually has a very good reputation on FTE.First Dually has a very good reputation on FTE.First Dually has a very good reputation on FTE.
With the trailer 13'-5" high, there are precious few options to gain bedrail clearance. I'd be tempted to raise the hitch and/or lower the pin box and then lower the rear of the truck to keep the trailer height under 13'-6". T believe you can gain about 2" using shorter blocks on the rear axle of your dually.
Old 12-20-2018, 08:39 PM
Edd505's Avatar
Edd505
Edd505 is offline
Edd505 is gaining momentum as a positive member of FTE.Edd505 is gaining momentum as a positive member of FTE.
5.5" clearance, 10k+ miles with no issues
Home when not on the road, NM sun is a killer
Old 12-22-2018, 10:47 AM
acadianbob's Avatar
acadianbob
acadianbob is offline
acadianbob is gaining momentum as a positive member of FTE.acadianbob is gaining momentum as a positive member of FTE.
Everyone has different circumstances but I know 5" is not enough clearance for me. I run 7" and at times have come within an inch of my bed rails; and that is even too close for comfort for me.
Old 12-22-2018, 07:23 PM
191124x7's Avatar
191124x7
191124x7 is offline
This is proving to be a perplexing problem. Turns out my hitch is already as high as it goes. Pin box does not seem adjustable, and I canít find anything online saying how to adjust them.
Trailer has very little room to grow taller anyway.
Sigh.
Old 12-22-2018, 07:25 PM
191124x7's Avatar
191124x7
191124x7 is offline
Would the truck sit with a negative rake unhitched if I do this? Would the headlights point to the sky when hitched if I do this?
Old 12-22-2018, 11:46 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
Unhitched the truck would be flat-ish, assuming that you have rake now. Air bags would probably be in order if you went with a shorter block to prevent excessive squat. With a shorter block you would have to adjust the headlights. It would be like putting in a leveling kit, the headlights need to be adjusted.
Old 12-25-2018, 10:33 AM
First Dually
I'd guess the truck will be way more level than now, but not negative rake even with a good sized trailer...but close! 😀
Air bags no different than now...nice, but no more necessary. Good if you want to adjust for ride/ride height or headlights.
Pin box might be able to be adjusted. May take drilling a hole on each side to keep the same number of bolts. Check with trailer manufacturer if in doubt.
Swapping to a pin box that positions the pin lower is another possible solution.
Happy holidays!
Old 12-25-2018, 06:14 PM
whooboy's Avatar
whooboy
whooboy is offline
whooboy is gaining momentum as a positive member of FTE.
The center of the tailgate is not the issue. It's the sides. Where I run into any problems with clearance is when pulling into a service station where the truck twists one way while the trailer twists the other. I have 6 inches of clearance and never had a problem with the trailer touching the truck (except the hitch, of course).
Old 12-25-2018, 09:09 PM
191124x7's Avatar
191124x7
191124x7 is offline
Thanks man, I appreciate it!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
