Adding Turn signals to an F-100
I'm curious if there is a retrofit kit available that anyone has experience with for adding an OE type turn signal mechanism into the original steering column bell under the wheel. My '55 currently has a functional clamp-on unit, but I'd like to have the self-cancelling feature and a cleaner, factory appearance if I can do it without scrounging up worn out original pieces.
Edit: here is the MidFifty link: http://midfifty.com/item.php?INV_ID=...-signal-switch . $73.95 . 12 volt
I'm using a factory unit from a '56. Because they have the dished steering wheel, I will need to bend the handle or buy one for a '53-'55.
As Abe pointed out, MidFifty has them. The others probably do as well.
Turn signal switch: 1953-60 Ford F-100 Turn Signal Switch - B6C-13341-A
Handle for '53-'56: 1953-56 Ford F-100 Turn Signal Handle, Chrome, Round ****
Wire clip: http://midfifty.com/item.php?INV_ID=1592&PN=Turn-signal-wire-retainer-black-painted-fits-all-truck-columns-32-66
Unfortunately, the handle is chrome. If I break the '56 handle trying to straighten it, I may have to try to paint the new one.
Vsanzbajo
16
07-13-2013 10:53 AM
saleen065
08-26-2008 09:35 PM
erinaldi
01-02-2008 02:05 PM
straightedge
06-05-2004 09:22 AM
