Serious Question about ReadyLift 3.5 kit
I have seen that the ready lift is a pretty popular option for people that are wanting a mid lift kit. After pricing the 3.5 ReadyLift kit out with the manufacturers recommended anti wobble track bar the price of the kit is $1450. That doesnt even come with springs or shocks. I then looked into A BDS 4 lift with Fox 2.0 shocks and and dual steering stabilizer with add a leaf and rear blocks and that kit comes to $1920.
For less than $500 more you can get a complete new suspension lift kit compared to a spacer kit that will save you very little in the scheme of things. Is there something that I am missing???
I am new to the Superduty family just picking up a 2012 F250 Lariat and am in the market for a mild 3-4 kit.
I look forward to hearing your thoughts and advanced thanks for your answers
I have ready lift 4" rear blocks, and a set of rough country 2.5" spacers in the front. Total lift is 2.5" in the front, and 2" in the back. Sits perfectly level. Total cost was less than $225 ($525 after bilstien shocks were installed) ready lift blocks were like 185 bucks and the spacers were somewhere in the 50 dollar range if I remember correctly. The ready lift 3.5" SST kit w/ track bar bracket that I see on there website is only $800, so I'm not sure where your numbers are coming from. There are no shocks with it, but with Bilsteins, you would only be at roughly 1100 bucks for the hole shabang. The BDS kit you mention is super expensive because it comes with coils instead of spacers. Any kit with full coils will cost some coin. If I were going to go to full coils in the front and get rid of my spacers, I wouldn't even look an any other brand other than Carli, and I would purchase their progressive coils. If your going to spend the money for a set of coils, they may as well be the best.
I don't know what size tire you plan on running, but I can run 37s with my current lift. Just an FYI.
Thanks for the reply and the information. The pricing I am getting is from their website. They have the 3.5” kit for $800 and the anti wobble track bar for $650. That’s where I got the $1450 price for the total setup. I’m sure I could piece together a setup from different manufacturers but I prefer to use the same manufacturers gear all the way around. So I feel like the value is better with spending the money on a lift with new springs and shocks unless there is something that I am missing.
Again thanks for the response. With over 130 views I thought I might have gotten a few more opinions. Hopefully more folks will chime in.
Also I plan on running a 35” tire specifically a 295/65/20
Look into bilstien, they actually make a Kit like the Carli system with longer 5100 series shocks and a longer progressive rate front coil. It’s only 2.5” but seeing as how you want to run 35’s that would be the perfect set up. Plus the lift is so mild it won’t affect your steering or suspension geometry (no adjustable track bar needed) that’s what I’m running on mine, I also ordered a set of 5” blocks for the rear to replace my stock 4” blocks. Pretty sure I’m the only person here that doesn’t like a level sitting truck hahahahaa
just a susggestion.
just a susggestion.
With 3.5", you shouldn't need to purchase a new track bar. The track bar relocation bracket should do just fine. I personally would not spend that much money on a 3.5" lift. If I was going to drop that kind of coin, I would buy the best of the best in a smaller lift. These trucks will run 35s in stock form. If you lift it more than 2", you may as well plan on running 37s so it doesn't look goofy.
just a susggestion.
just a susggestion.
BDS, ICON, and Carli all make very good lift components for these trucks. You may also want to look into PMF (pmfsuspensions.com) since you have decided to stay at 2.5" of lift. They have some awesome stuff, and it is great quality, but their prices are comparable to Carli.
For you viewing pleasure and to see what 35s with 2.5"s looks like. The 35s are worn, and the step bar is bent making the truck look like it has a rake, but i does not. Sits completely level. If I had of done more research, I would have stayed stock and ran 35s that way, but at least now that I'm lifted, I can change rims and not have to worry about scrubbing.
I have ran RC lifts before, and was tempted to buy their full kit for this truck, but I originally thought I was going to leave the back alone and only level it. Long story short, it had the calli lean, dog squat, etc. look after only leveling and I hated it. Had to bring the rear up a couple inches, and it ended up like it is now. One thing I like about PMF is that their rear blocks are angled on the top to eliminate the need for the driveshaft carrier bearing spacer and angle the rear pinion upward and get a more factory pinion angle. The spacer is only used on crew cabs, extended cabs like mine do not need it (no carrier bearing, the driveshaft is one piece) but I think my pinion angle is a little off because of how much lift I have, and I may be wearing some u joints down prematurely. The PMF blocks would fix that, and are on the list of things to do.
There is a guy that frequents this forum, his name escapes me right now, but he has a mixture of Carli and PMF stuff on his truck and says it rides like a Cadillac. Looks amazing too. Black Crew Cab long Box truck with silver and black 17" rims. Check around in the picture threads to find him.
