Serious Question about ReadyLift 3.5 kit
#123
#125
So another question about my upcoming lift. I currently have 20x9 XD badlands with +18 offset and 5.71 offset. I am planning on going with a 35x12.5 tire. Will those tires with my current wheel specs work without any rubbing?
Also my truck has about 67,000 miles and am wondering while Im doing the lift are there any other parts I should just go ahead and preventatively replace?
#126
#127
Hey guys! So I have ordered the zone 4” lift with new control arms but am debating the tire size. I like the 37” but my big concern is going to the 37” everything I have read says it will kill the performance even though I have the 6.7 with 3.55 gears. I really want to avoid a gear swap so if it were you based purely on performance would you do 35” or 37”? I don’t mind taking a slight hit but dont want it to make me hate driving it and effect towing performance to the point that the truck is struggling. I might be trying to have my cake and eat it to but wanted to hear your thoughts.
#128
Glad to hear you got it ordered! I think you’re gonna be a lot happier goin with the Zone Radius arms vs the cheaper route. With the torque your engine puts out I wouldn’t hesitate running 37s one bit. There’s so much talk about re-gearing when going up in tire size. I’m not saying I wouldn’t like to put 4.88s in mine, because I do plan on that someday. But I don’t have any problems pulling my 10k lb houseboat 200 miles through the hills of North Arkansas. And that’s with a 6.2 gas and 3.73s. Get the 37s. Can’t wait to see this come to fruition
#129
I would not hesitate to run 37's with 3.55's on your 6.7. If you're loaded extremely heavy and get into some hills, simply lock out 6th gear. 5th is still an overdrive gear. I can promise you that if you are debating 37's, that means you want them, and you want be happy if you purchase 35's. 37's just fill the large wheel wells of these trucks so much better. Just make sure your wheel offset and width is correct.
#130
Go big or Go home...I have 3:73s with the 6.2L, and yes I do notice a difference from when it was stock, but I had 35s on it before this and there wasn't enough of a change when I went to 37s to notice a difference between the old 35s and new 37s.
I will say this I put 35s on mine, and the entire time I had them, I wondered what it would look like with 37s. I won't ever put 35s on it again. Go with the 37s.
#131
Well I’m going to talk with a couple of tire shops and if they can confirm that the 37s will fit without any rubbing or trimming on my current wheels I will go with them.
i was dead set on getting the Nitto Ridge Grapplers but after seeing the price and some reviews on the Falken Wildpeak AT3W I think I might give them a shot. It’s a savings of over $500 going with the Falkens. Anyone have any knowledge or experiences with these?
#133
#135
9” wide with +18 offset
