Serious Question about ReadyLift 3.5 kit
#106
So after reading through this I have a few questions for the people here. Seems a lot are running 37s just leveled. Well I just bought a 2011 F250 CC and it was already leveled with a 2 lower block. A few people told me that would clear 37/13.5s easily and fine on the 22x10 -18 rims I had already bought for my previous f250. Well I got tires and now major rubbing. Changed out coil springs to RC 1.5 lift springs. Still Rubs!!! Whats the deal here? Is it because my front bumper is soo heavy? Or am I missing something? About to just buy a 6 lift but I really like the leveled 37 look. Was gonna add bilstiens and run it but I dont want rubbing.
#107
#108
Your truck looks great, btw.
Originally Posted by Chuckfx4350
I have a question for Ron 94150.
Browsing through the the forum I came across a thread that you started posing the question ReadyLift 3.5” vs Zone 4” lift. It’s obvious you decided on the ReadyLift so what was your determining factor for your decision?
I was on a budget, and gearing was priority with my gas motor.
I tow. Usually just local, but once a year or so, we take a family camping trip. I know how my factory springs perform.
I'm not hand washing this things all the time, but I keep it clean. After measuring the clearance bar from the cab, I didn't think a 4" lift would work with 36.6" tall tires. Turns out, I was right. If I hit the brakes hard at the gate, I can make the cab hit the clearance bar! This is the same reason I haven't installed cab lights.
Last, I like the stuffed look. And while 1/2" isn't a lot of difference, I'd run a even smaller lift if I could. But I did want an aggressive offset, with an inch or so of tire sticking out, what I've always ran since I lifted my first Bronco.
#109
I would make sure your F350 has the 4" tall rear blocks. I'm almost certain that all the F350s had the 4" blocks from 11-16, but I would double check. If for some reason you have 2" rear blocks, the 2.5" in the front will give the squatting dog look. Trust me, I know. I put just the front leveling kit on first thinking it would be good to go, then had to turn around and lift the back as well.
#110
I did new shocks, but I could have gotten away with shock extender brackets.
To the guy above running 37x13.50 on a 10" wheel, they will always rub. They will rub the radius arms even if you buy a 6" lift. That wheel and tire combo are going to rub something no matter what. I have 2.5" in the front on mine and 2" in the back, and my 37x12.50s only rub the radius arm at full lock. They are on 20x9 -12 offset. It would clear a little better if you went with more than 1.5" of lift in the front, but from what I learned, 1.5" is pretty much level with no mods to rear, anything over that, you will be lifting the rear as well.
#111
Several factors....
#112
#113
My first thought was, there is no way those kits are close to the same price. But after looking, it appears the zone kit has come down in price and the readylift has gone up. When I was shopping 2 years ago, that base zone kit without radius arms was right at 1k. It's now just over 800. I paid just over 500 for my readylift kit. The best price I can find now is 700. For that price difference, I would go with the zone kit if I were you, if nothing else, just for the shocks. Not to mention a trac bar vs drop bracket.
#114
So here are a couple of pics of my F250. Definitely needs some elevation. Parked next to other F250s that are stock its always lower. I also took some measurements and from the center of the wheel to the bottom of the fender its 24.25 in the front and 24 in the rear. Seems lower than it shoul be to me but not sure.
#115
#116
#117
I totally agree, its a no-brainer. Is it just me or is this the longest anyone on here has ever debated what lift to go with?! Lol just pokin fun Chuck
#118
I think somebody entiende that same thing on the mustang forum i used to belong to. You ever have been on a mustang forum!?
#119
#120
