Serious Question about ReadyLift 3.5 kit
#91
I have ready lift 4" rear blocks, and a set of rough country 2.5" spacers in the front. Total lift is 2.5" in the front, and 2" in the back. Sits perfectly level. Total cost was less than $225 ($525 after bilstien shocks were installed) ready lift blocks were like 185 bucks and the spacers were somewhere in the 50 dollar range if I remember correctly. The ready lift 3.5" SST kit w/ track bar bracket that I see on there website is only $800, so I'm not sure where your numbers are coming from. There are no shocks with it, but with Bilsteins, you would only be at roughly 1100 bucks for the hole shabang. The BDS kit you mention is super expensive because it comes with coils instead of spacers. Any kit with full coils will cost some coin. If I were going to go to full coils in the front and get rid of my spacers, I wouldn't even look an any other brand other than Carli, and I would purchase their progressive coils. If your going to spend the money for a set of coils, they may as well be the best.
I don't know what size tire you plan on running, but I can run 37s with my current lift. Just an FYI.
#92
I'm not sure why I put the spacer's were from rough country in that post. You are right though, RC spacers only go up to 2". I have these in 2.5". (2005-19 Ford F-250/350 BMC Spacer) There are much cheaper versions of the bottom mount spacers, but I liked the fact that these mold to shape of the axle mount and aren't just circular. The cheaper ones won't go anywhere even though they aren't molded to the shape of the axle, because they are bolted on, but these just gave me peace of mind.
#95
#98
I have no idea what the springs rates are. There were different packages that had different springs. For example: My truck has the heaviest duty rear springs (I think it was called a camper package). The front coil springs were all the same I believe. Only the rear leafs had different rates.
#99
I started thinking about spring ratings after yesterday when I rode in a different 250 with a BDS setup and another ReadyLift setup back to back. The BDS with new springs seemed a little stiffer than the ReadyLift with the stock springs.
#100
There are different front coil spring packages. I don't remember the rates offhand, but I believe they range from 4500 to 6000 lbs. A truck with the snow plow prep package will sit 1-2 inches higher than a lower rate truck. Of course, the lower rates will ride better. I'm sure someone else will chime in with the exact numbers offered.
Edit, a quick google search found this https://cimg5.ibsrv.net/gimg/www.for...cfe3f99d6.jpeg
So yes, unloaded heights can be all over the place.
#101
Im in Florida so I wouldnt think that the trucks I am comparing mine to would have a snow plow package but I could be wrong.
#102
Another question can someone tell me why these 37” tires are so cheap? More than $150 cheaper than other 37” AT’s
https://www.discounttire.com/buy-tir...-a-t3w/p/39667
#103
#104
#105
