2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Annoying honk when exiting truck.
Old 12-17-2018, 08:52 AM
Logan1080's Avatar
Logan1080
Logan1080 is offline
So if I get out of my truck with the key fob in my pocket while it's running, the truck honks the horn twice when I close the door. This is beyond annoying. Is there a way to shut this off? Thanks.
Old 12-17-2018, 09:06 AM
alabamatoy's Avatar
alabamatoy
alabamatoy is offline
Same here. See "forscan spreadsheet" thread, or go to dealer apparently.
I have DLed forscan, purchased BT OBD-II dongle, but havent had time to implement yet.
Or, as someone pointed out in another thread, leave the keyfob inside the truck.
Old 12-17-2018, 09:41 AM
KCRebel's Avatar
KCRebel
KCRebel is offline
Yes as suggested above using Forscan. I printed the spreadsheet out, highlighted the options I wanted to change and spent about half an hour making the changes. Super easy once you get the required software and hardware connections so everything will communicate. The forscan guys are awesome for any tech support you may need as well. forscan.org is where they are located.
Old 12-17-2018, 09:53 AM
GABAR's Avatar
GABAR
GABAR is offline
The easiest way to stop this is to not "fully" close the door. Just push the door to the first click and it will not honk at you.
Old 12-17-2018, 09:57 AM
Beast2.0's Avatar
Beast2.0
Beast2.0 is offline
Make sure you also do the Secure Idle/Police mode. This will prevent an unwanted drive-off without FOB in truck. I did this with my '18. Honk gets to be irritating !
Old 12-17-2018, 11:07 AM
Carnac22's Avatar
Carnac22
Carnac22 is offline
I asked the dealer to turn off the double honk upon door close (exit) with engine running - was told that it is a safety issue and they couldn't (wouldn't) do it.
Forscan is a good option. I also want to turn-on oil life percent remaining option.
Jim
Old 12-17-2018, 11:52 AM
Beast2.0's Avatar
Beast2.0
Beast2.0 is offline
Jim
I've looked for that and haven't been able to find the Forscan changes needed. Anyone out there that has and knows what needs to be changed?
Old 01-08-2019, 05:18 PM
RenoHuskerDu's Avatar
RenoHuskerDu
RenoHuskerDu is offline
I'm in the same boat as you. Just got FORScin, hooked it up, and WOWOWOWOW look at all the freakin modules. 5 screens of them on my android! Where to start???
I'm going to look at the Spreadsheet thread (https://www.ford-trucks.com/forums/1...readsheet.html) and see if I can figure it out. Race ya!
Old 01-08-2019, 07:30 PM
txsd's Avatar
txsd
txsd is offline
I don't think you can add the oil life percentage, at least not on a 2017. You can view it within Forscan Lite though.
Davydee
2017+ Super Duty
16
06-29-2018 02:13 PM
Chris3
2017+ Super Duty
05-28-2018 03:42 PM
invstr55
2017+ Super Duty
09-15-2016 09:24 PM
Big-Red-Lariat
2015 - 2020 F150
06-22-2016 03:57 PM
dennisinmo
1997 - 2003 F150
07-22-2004 07:17 PM
Quick Reply: Annoying honk when exiting truck.
