my doors seem do what they want to, sometime they will lock and half way, i replay the relays under the dash and have the problem, what should i do now?
Certain year Ford lock actuators are known to be weak. Does it work ok with the engine running, but iffy with it off? The voltage in the system will be a little bit higher with the engine running, and that may be enough to make a weak lock motor work. Like the other poster said, lube may help it also.
