Soften the ride of an empty F350 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 12-16-2018, 09:47 PM
theoldwizard
theoldwizard is offline
theoldwizard is starting off with a positive reputation.
MY son-in-law got a good deal on a 2017 F350 STX with 6.2L. He was shopping for a F250, but this was a good deal. However, most everyone knows what an empty F350 rides like ! They will be towing a trailer, but it is less than 8,000 lbs.
Any ideas on improving the empty ride quality ?
Old 12-16-2018, 09:49 PM
acelefty
acelefty is offline
acelefty is starting off with a positive reputation.
Let a bunch of air out of the tires. From there, the mods get more expensive.
Old 12-16-2018, 09:51 PM
h20camper's Avatar
h20camper
h20camper is offline
h20camper is gaining momentum as a positive member of FTE.h20camper is gaining momentum as a positive member of FTE.
Lower the tire pressure! Try 50 PSI when unloaded. Adjust appropriately when loaded.
Old 12-16-2018, 09:54 PM
RandyinTN
RandyinTN is offline
RandyinTN is starting off with a positive reputation.
Will 50 PSI set off the TPMS light?
Old 12-16-2018, 10:02 PM
h20camper's Avatar
h20camper
Yes. Use FORScan to adjust that. I did.
Old 12-16-2018, 10:11 PM
Imadentguy
Imadentguy is offline
Imadentguy is starting off with a positive reputation.
Im not sure what the factory recomended pressure is on the 350 but on my 250 i run cold 51 in the fronts and 61 in the rears with no light. I throw tpms if it drops below 50 in the front and 58 in the rear. The ride quality is dramatically better then when its set at the loaded recommendation of cold 60f 70r.
Old 12-16-2018, 10:17 PM
Imadentguy
For you guys that use forscan..... does ford give you any problems for adjusting from factory parameters? Had a bad experience with GM because i adjusted for tire size increase of 5%. No other adjustments and no tune. They were adamant about voiding my powertrain warranty.....
Old 12-16-2018, 10:49 PM
UGA33's Avatar
UGA33
UGA33 is offline
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
They would have a tough time figuring out changes you have made. Plus, all the changes you make are technically changes they have designed and written anyways.
Old 12-16-2018, 10:57 PM
Imadentguy
Cool! Thank you sir.
Old 12-17-2018, 07:34 AM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.
My F350 rides pretty dang good when empty. Maybe your SIL needs a Chevy 1500 if he wants a good ride
Old 12-17-2018, 09:08 AM
mattymax
mattymax is offline
mattymax is starting off with a positive reputation.
I kinda agree. Had a f350 as a rental. Rode pretty close to my Chevy 2500HD. I like how these trucks feel on the road. The 1500s ride too good imo
Old 12-17-2018, 09:28 AM
SDcrewzer's Avatar
SDcrewzer
SDcrewzer is offline
SDcrewzer is gaining momentum as a positive member of FTE.SDcrewzer is gaining momentum as a positive member of FTE.
Lightbulb
Our 2019 F350 6.2 4x2 with the camper package (2x front spring upgrade) rides rather rough and jittery when lightly loaded and with the tires inflated to GVWR spec (60F and 80R cold). Dropping them down to 55F and 65R cold has helped considerably. No TPMS alert yet.
HTH,
Jim / crewzer
Old 12-17-2018, 09:29 AM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
Absolutely! I drove mine yesterday on the highway unloaded and I think it rides better than my wife's Hyundai Santa Fe Sport. I do have the Rancho RS9000XL shocks on it but the rears were cranked up to 8 or 9 so it was fairly stiff. I was running the tires at 60 front, 80 rear. I tow most of the time so I don't bother airing down.
Old 12-17-2018, 09:30 AM
Joe T
Joe T is offline
Joe T is starting off with a positive reputation.
F250 rear springs and put the lightest front spring available for the gas motor in the front. And change shocks. Sulastic rear shackles?
17 inch wheels with 315/70/17, can get those below E rating and still decent capacity. Little light duty for the superduty but will work.
Not much else unless you want to spend big bucks.
Old 12-17-2018, 09:31 AM
mgpsfan
mgpsfan is offline
mgpsfan is gaining momentum as a positive member of FTE.mgpsfan is gaining momentum as a positive member of FTE.
Can try Sulastic. Sulastic
I had them on my '05 F250 and it was a noticeable difference.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
