I'm confused about a few of the options on my F350 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 12-16-2018, 08:01 PM
191124x7's Avatar
191124x7
191124x7 is offline
191124x7 is gaining momentum as a positive member of FTE.
I'm wondering first about the 'Dual Extra Heavy Duty Alternators' option. Does this help me with my fifth wheel? Like, running my 1000w inverter while driving, and charging my RV battery?
Next, can somebody explain what the 'Rapid Heat Supplemental Heater' is and how to use it?
Finally, the 'Engine Block Heater.' Doesn't this normally have a cord hanging out of the front grill? I've looked and can't find one.
Thanks!
Old 12-16-2018, 08:08 PM
sc954rr
sc954rr is offline
sc954rr is starting off with a positive reputation.
The dual alternators are automatically added when the rapid supplemental heater is installed I believe, the rapid heater is an electrical heater in the vents that is used when outside air temp is less then 40 I believe and the truck coolant temp is under a certain temperature I believe 120 but don't quote me on that....I have it and love it, it's great for those cold mornings when the truck just isn't warm enough yet from remote start so it gives you some warm air till you get driving and it is just automatically controlled by the truck so no settings/adjustments. The Engine Block Heater cord I believe is tucked and clipped to the top of bumper I believe I read in another thread from factory but not a 100% sure as it hasn't been that cold where I am for me to go looking for it yet...
Old 12-16-2018, 08:21 PM
orion250's Avatar
orion250
orion250 is offline
orion250 is starting off with a positive reputation.
Feel up around passenger side tow hook for block heater cord.
Old 12-16-2018, 08:25 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
All 6.7 trucks come with dual alternators as standard. When supplemental cab heat is selected so is the upgraded dual heavy duty alternators.
Old 12-16-2018, 08:29 PM
Mud Doc's Avatar
Mud Doc
Mud Doc is offline
Mud Doc is starting off with a positive reputation.
Your dual alts would only help with the trailer charging IF you had a lot of other stuff sucking power, like a snowplow--not likely towing... You get only the same charging ability that is possible to push power thru about 20' of small gauge wiring and several connections + the tow harness. It usually ends up being just enough to keep a well-charged battery up, but really not enough to charge deeply discharged batts. This is from experience with 6 different superdutys over 16 years.
The RSH is totally automatic when the temp/truck are both cold enough.
The block heater won't be needed unless you will be spending a lot of time in really cold temps. New SDs start really easy when cold, even below zero.
ATC_F350
ATC_F350 is offline
ATC_F350 is starting off with a positive reputation.
Make sure and read how to use the Rapid Heat. It's not a hot heat and works best with lower fan speeds, to gently heat the truck.
Old 12-16-2018, 11:26 PM
jjac81
jjac81 is offline
jjac81 is starting off with a positive reputation.
For what it's worth, I believe rapid supplemental heater is always included on trucks sold to cold weather markets. At least that is what my salesperson said.. For one, all SD sold in Michigan, where I live, have them...and thus also dual alternator.
Old 12-17-2018, 12:40 AM
someday
someday is offline
someday is starting off with a positive reputation.
the dual alt option in the past was pretty rare and i wouldnt recommend because parts would be harder to come by and more parts to go south...since its pretty much standard now its something less to worry about. i was always 50/50 about it years ago, pluses and minuses
Old 12-17-2018, 07:44 AM
RONMCHUGH's Avatar
RONMCHUGH
RONMCHUGH is offline
RONMCHUGH is starting off with a positive reputation.
^^^^^^^^^^^ What he said ^^^^^^^^^^^ Mine is clipped in there .
Old 12-17-2018, 08:22 AM
18CCLBKR's Avatar
18CCLBKR
18CCLBKR is offline
18CCLBKR is starting off with a positive reputation.
Your wiring to the trailer is at best 12ga (more likely 14ga or smaller). At 25 foot (also estimation) 12 GA would only carry10amps. A 1000w inverter will pull almost 92amps 12v at full output. So charging an rv while towing through the 7 pin plug provides very limited amperage. Dual alternators is only for the diesels in cold climates iirc. Can you get the supplementary heater in a gas?
Old 12-17-2018, 08:38 AM
EWeezY's Avatar
EWeezY
EWeezY is offline
EWeezY is starting off with a positive reputation.
It's funny you say that. I purchased my truck in North Dakota. No supplemental heater, no block heater..... I mean come on.... But I do have the extra heavy duty alternator.....ughhh
Old 12-17-2018, 08:58 AM
NorEasterMA's Avatar
NorEasterMA
NorEasterMA is offline
The Lighting Guy
NorEasterMA has a very good reputation on FTE.NorEasterMA has a very good reputation on FTE.NorEasterMA has a very good reputation on FTE.
My truck originated in NH. Block heater (gas truck) and the extra extra heavy duty alternator but no rapid supplemental heater. Who knows?
Old 12-17-2018, 09:07 AM
wrvond's Avatar
wrvond
wrvond is offline
wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.
Supplemental heater is not available for gas units, sorry.
The block heater connector is stored above and to the right of the passenger side tow hook. The clip that holds it can be broken, so be gentle when pulling it down and putting it back.
Old 12-17-2018, 09:20 AM
SDcrewzer's Avatar
SDcrewzer
SDcrewzer is offline
SDcrewzer is gaining momentum as a positive member of FTE.SDcrewzer is gaining momentum as a positive member of FTE.
Exclamation
Originally Posted by ford390gashog View Post
All 6.7 trucks come with dual alternators as standard....
The 2019 Order Guide indicates otherwise:
HTH,
Jim / crewzer
Old 12-17-2018, 09:26 AM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
The truck doesn't provide much juice to the RV. I ran all three of the tank heaters on the way home last month and the trailer batteries were pretty low by the time I got home. That was disappointing.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
