Head Coolant Recirculation Kit Query
At 13:21 he talks about the coolant return lines. Further along in the video he gets into some things that you may want to consider while you're all apart.
https://youtu.be/XxWDHosASg4
So I'm in pondering mode about the coolant recirculating kit. This guy I can watch for about 30 seconds. Proving the theory about a blind squirrel, during that 30 seconds he mentions an air pocket at the back of the head, and that's something I've thought about for more then 6 months. AKBlackfoot's experience with the coolant recirculation kit solving a coolant overflow issue, and why it's the passenger side head that typically, not exclusively, cracks and gets fuel into the coolant is the second part of what has had my curiosity up.
But I'm trying to figure out how this kit actually works. Coolant primarily comes up through the block to the back of the head and moves forward to the exit back to the block and water pump. There is definitely an area that can have an air pocket which can alter the Degas bottles compressed air volume, the air reservoir.
In the head gaskets there are restrictive orifice bleed holes at the individual ports located in the larger ports for both the head and deck surfaces. They move some coolant and from my understanding also help to eliminate any air pockets at the top of the cylinder jackets. The ports are eliminated at the front of the block.
At the back of the head the kit installation is straightforward.
The other end of the hoses go to the base of the front cover where the thermostat resides.
So this is often referred to as increasing the flow in the heads, and I can't see how it does that considering the coolant flow paths. I can see when the T/S is closed flow going from the back of the heads towards the radiator, bypassing the T/S. And with the T/S open, acting with a Venturi effect, the main flow of coolant through the T/S pulling coolant out of the hoses. But either of these situations do not flow more coolant through the heads, they bypass the heads going from block jacket to radiator.
So to me this would act as an air entrapment relief, similar to the bypass hoses going to the Degas bottle from the EGR cooler and also the radiator top tank.
Am I thinking about this wrong from too many hours starting at a block and heads?
If this really only is about relieving any air pockets then a smaller pathway with maybe a directional change direct to the Degas bottle could be just as effective without disturbing the flow through the heads.
Maybe only interesting to me, but the first cousin of the 6.0, the 6.4, gets head gaskets where the lower flow ports get a more wide open pathway at the center two cylinders. Does it mean anything, God and International engineers only know.
Where the hoses get tapped into the head, theres no restriction. Theres definitely a good flow of coolant through them and they are hot to the touch when upto temp. I used the Driven Diesel kit.
I know it worked for AKBlackfoot to eliminate the puke problem he had without gasket failure, but now I'm wondering if it did that just with "burping" the back of the head, not so much flow.
Edit - from my perspective I don't think the highest thermal transfer to coolant is in the block, but within the heads.
These are 1/4 fittings and hoses I believe (at least the fittings) so they can't flow mass quantity of liquid.
The Cummins kit that I know of moves coolant from the water pump to the back of the block to avoid the issue of scorching the rearmost cylinders. It adds a fixture replacing the rear core plug and the coolant is going to the back cylinders and up through the head. At first, I thought these kits were doing that until I looked closer at the connections to the front cover.
If you don't mind me using your picture as its the best, here's my sort of animation. Narrative on the fly.
I may be totally wrong, it's a discussion.
Are you installing the fuel line kit that ties both heads together via the rear fuel rail ports? If so careful on the angle you drill them on. The fuel line kit is from Amazon sold by TamerX. Heres some pics from my install.
No Pete, not tieing the fuel together. Also not using any kit, building my own with stainless tubing and stainless Swagelok 1/8" npt / 3/16" tubing fittings. Although the fuel might clear these.
If I'm following you correctly: the head gaskets themselves are the flow restrictor(s). If this is the case, then any of us with "commonized" 6.0s would have the newer gasket, and the "different" (only God and International knows) coolant flow? So, yeah, I think it is of interest to the owners of later 6.0s, as in what problem were they solving and does it help our engines?
Nice work on the bleed hoses, btw...
Scott
Short answer, the 18mm and 20mm don't change, it's the 6.4L.
Not my hoses, I'm going tubing.
Scott
Second, Jack if you're using hardline be sure to secure it along the way with retainers or clamps. The harmonics may reap havoc on them resulting in cracks ect.
Oh and to add, are you making a jig to duplicate these hard lines so you could offer a kit? 🤐
Nah, no kit. Not my thing.
Black plated high-pressure brass tee and ell, stainless Swageloc. Not necessarily in this configuation.
Possibly this routing, using Adele clamps off the HPOP cover bolts or / and the intake stud. Have to have it together to see the layout, especially with the '03 ICP sensor.
I was thinking about remote mounting the ICP sensor too. The cover can be redrilled and tapped for NPT to Swagelok, but the problem is the sensor end. That o-ring fits into a tapered recess, not a flat or square fitment, a lot of compression for a tight seal at these pressures. Used covers are cheap to play with. But I pretty much gave up on that.
