1977 F250 Lap Belts - Ford Truck Enthusiasts Forums
1977 F250 Lap Belts
Old 12-16-2018, 11:49 AM
high6
high6 is offline
high6 is starting off with a positive reputation.
1977 F250 Lap Belts
I have a 1977 F-250 Highboy (somewhat) that just had lap belts. I've been looking and looking, can't find what the originals look like or where to get a set. LMC and other places seem to just have a universal set. Did they have a retractor from the factory? Where was the male side, and female side of the seatbelt?
Thanks,
Tobin
Old 12-16-2018, 12:17 PM
beartracks's Avatar
beartracks
beartracks is offline
beartracks is gaining momentum as a positive member of FTE.
https://www.seatbeltplanet.com/
They have two sections, replacement and repair. Nice to work with.
Old 12-16-2018, 12:24 PM
butcher7788
butcher7788 is offline
butcher7788 is starting off with a positive reputation.
Well my 11/76 has the lap/across the chest type of affair and the female ends are in the center of the bench seat and the retractable male ends are outboard.
high6
high6 is offline
Thanks, I was looking at their stuff but will have to give them a call since they don't have any lap belts listed except for the center seat.
Old 12-16-2018, 12:26 PM
high6
high6 is offline
So it does have retractable male ends on the outboard side! Do you have any pictures? That is what I needed to know. Now to find a set!
Old 12-16-2018, 12:42 PM
butcher7788
Drivers side bottom.
Old 12-16-2018, 12:44 PM
butcher7788
Passenger top.
Old 12-16-2018, 02:20 PM
high6
high6 is offline
Thanks, but that I just have a locations to mount a lap belt, no shoulder harness.
Old 12-16-2018, 02:35 PM
butcher7788
No prob. Now you owe me air cleaner vacuum routing pics. Tit for tat, bud!
Old 12-16-2018, 02:38 PM
high6
high6 is offline
Well, I would if I could but I have a 12 valve Cummins diesel in mine. No reason to have any vacuum lines on your air cleaner, I would get rid of that.
Old 12-16-2018, 02:42 PM
caravaggio2000
caravaggio2000 is offline
caravaggio2000 is gaining momentum as a positive member of FTE.
My 73 F100 is lap belt only. The female sides are on the bench, not retractable. The male side is located on the sides of the seat and retract about a foot. I can take a picture later if you need one.
Old 12-16-2018, 02:44 PM
high6
high6 is offline
Perfect, exactly what I need. A couple pictures would be great if you could.
Thanks!
Old 12-16-2018, 02:45 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
No seat belt retractors with lap seat belts.
1967/75 F100/350, 1976/77 F250 4WD (High Boys): Lap seat belts were standard equipment, shoulder straps were optional.
With shoulder straps, the lap belts have two buckles. One for the tongue of the lap belt, another for the tongue of the separate shoulder strap.
The separate shoulder straps attached to the upper right & left corners of the cab, once the rubber plugs were removed. See 1973/75 pic below.
Old 12-16-2018, 02:52 PM
butcher7788
Damn. Ah well.....the only dumb question is the one not asked.
Old 12-16-2018, 03:34 PM
caravaggio2000
Here you go.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
